Install this single-port 10GbE PCI Express (PCIe) Network Interface Card (NIC) into a server or computer to enable faster network speeds and enhanced network functionality. This card supports six speeds: 10/5/2.5/1Gbps and 100/10Mbps. The variable speeds permit access to legacy hardware. Alternatively, the 10GBASE-T and NBASE-T capabilities ensure compatibility with the latest network switches and network access points manufactured by Cisco ; HPE ; and Aruba .
Increased Network Speeds
This PCIe network card provides access to increased bandwidth. It reduces network slowdown/degradation when running data-intensive applications/processes such as FTPs, online storage/backup, and when streaming online content. NBASE-T technology maximizes the capability of Cat5e copper cabling over at distances of up to 100 meters. The Ethernet network card supports a 10 Gbps connection over copper using existing Cat6 (or better) copper cabling. -
Enhance Existing Hardware
The Network Interface Card connects via an available PCI Express x2 3.0/4.0 (or higher) expansion slot. The card is shipped with a standard-profile bracket and includes a low-profile bracket for installation in various systems. This card is compatible with Windows, Windows Server, and Linux. Take advantage of advanced features such as Audio-Video Bridging (AVB), VLAN tagging, 16 K jumbo frame, full-duplex, secure boot, and PXE. The PCI Express 10G NIC is backed for 2-years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 1-Port 10Gbps PCIe Network Adapter Card, Network Card for PC/Server, Low Profile PCIe Ethernet Card w/Jumbo Frame Support, NIC/LAN Interface Card - Marvell AQC113CS Chipset, PXE Boot (ST10GSPEXNB2) - network adapter - PCIe 3.0 x2 - 10 Gigabit Ethernet x 1
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 3.0 x2
- PCI Specification Revision
- PCIe 3.0, PCIe 4.0
- Ports
- 1.5 cm x 10.6 cm x 5.6 cm
- 73 g
- Cabling Type
- NBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
- Data Transfer Rate
- 10 Gbps
- TCP/IP, UDP/IP
- Processor
- 1 x Marvell AQC113CS
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz, IEEE P802.3az
- Black
- System Requirements
- Windows 8 / 10 / 11, Linux 3.10.x or later LTS versions only
- 2-year warranty
- Network adapter
- Form Factor
- Plug-in card
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- NBase-T
- Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
- 10 Gbps
- TCP/IP, UDP/IP
- Status Indicators
- Link/activity
- Full duplex capability, secure boot, EEE, 16 KB Jumbo Frame, VLAN Tagging, AVB, Auto MDIX, PXE boot
Processor / Memory
- Processor
- 1 x 100M/1G/2.5/5/10 Gigabit Ethernet - RJ-45
- Included Accessories
- Low-profile bracket
- RoHS, RCM
- Black
- OS Required
- 1.5 cm
- 10.6 cm
- 5.6 cm
- 73 g
- Shipping Width
- 3.5 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 14.5 cm
- Shipping Weight
- 151 g
- Limited warranty - 2 years , Technical support - assistance - lifetime
- 0 °C
- 60 °C
StarTech.com 10G PCIe Network Adapter Card | In Stock | £125.14 |
