StarTech.com 2.5in SATA Hard Drive to 3.5in Drive Bay Mounting Kit
Quicklinx: 5D2XWS00 Mfr#: BRACKET25SAT
Hurry, only 1 left in stock!
£4.38 ex VAT
£5.25 inc VAT
Express delivery Order within the next 18 hours for delivery on Monday
Mount a 2.5in SATA hard drive to any desktop with an available 3.5in bay. This Serial ATA hard drive mounting kit allows you to install a 2.5in SATA hard drive in a 3.5in drive bay. The 2.5in to 3.5in SATA hard drive mounting kit features a sturdy aluminum bracket, as well as a combined 7+15 pin SATA + LP4 Power to SATA cable - which helps simplify installation and reduce clutter within the computer case.
StarTech.com SSD Mounting Bracket - Solid Metal - 2.5in to 3.5 Hard Drive Adapter - SSD Bracket - SSD Upgrade Kit (BRACKET25SAT) - storage bay adapter
Storage bay adapter
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Aluminium
9.8 cm x 10 cm x 1 cm
110 g
P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, ST521PMINT
Storage bay adapter
Product Material
Aluminium
Storage Controller
No CPU
Bays
1 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
1 x Serial ATA cable - internal
RoHS
9.8 cm
10 cm
1 cm
110 g
