StarTech.com 5 Pack - 2.5" SSD / HDD Mounting Bracket for 3.5" Drive Bay
Quicklinx: FK1TWS00 Mfr#: BRACKET125PTP
Type: Storage bay adapter
HD Size: 2.5 / 3.5 shared
Power Supply: [N/A]
£16.62 ex VAT
£19.94 inc VAT
The 2.5" SDD / HDD Mounting Bracket for 3.5 Drive Bay now comes in a convenient 5-pack. This mounting bracket lets you quickly install a 2.5" SSD or HDD into a single 3.5" bay in a desktop PC or server, with no tools required. The tool-less mounting bracket supports a 2.5" solid-state drive or hard drive from 7 mm to 9.5 mm in height.
The mounting bracket's tool-less design makes it fast and easy to install a 2.5" drive in a computer or server, without the need for additional hardware or tools. It's ideal for system administrators and integrators who are building or upgrading a computing solution for a wide range of businesses and organizations, including schools and hospitals, saving valuable time and effort on installation projects.
The lightweight mounting bracket is designed for trouble-free, reliable performance. To install a drive, you simply secure it into the mounting bracket, without using tools. Then, you put the bracket into a 3.5" drive bay in your computer and the bracket holds the drive in place using the tool-less plastic pegs.
StarTech.com 2.5 SSD/HDD Mounting Bracket for 3.5 Drive Bay - 5 Pack - Tool-less - Hard Drive Mounting Kit (BRACKET125PTP) - storage bay adapter
Storage bay adapter
Packaged Quantity
5 (specifications are for single item)
Supported Form Factor
3.5" to 2.5"
Expansion Bays
1 x internal - 2.5"
Compatible Bay
1 3.5"
Product Material
Plastic
10.2 cm x 15 cm x 1.3 cm
33 g
Packaged Quantity
Storage bay adapter
3.5" to 2.5"
Product Material
Plastic
Storage Controller
No CPU
Bays
1 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
30 plastic pegs
Tool-less
RoHS, WEEE, REACH
10.2 cm
15 cm
1.3 cm
33 g
Shipping Width
15.5 cm
Shipping Depth
9.5 cm
Shipping Height
11 cm
Shipping Weight
40 g
FK1T StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £4.60
FK1T StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.26
FK1T StarTech.com 12in Latching SATA Cable In Stock £5.48
FK1T StarTech.com 18in Latching SATA Cable In Stock £3.94
FK1T StarTech.com 24in Latching SATA Cable In Stock £6.08
FK1T StarTech.com 6in SATA Power Y Splitter Cable Adapter - M/F In Stock £6.62
FK1T StarTech.com 6in Latching SATA Cable In Stock £5.08
FK1T StarTech.com 2.5in SATA to Mini SATA SSD Adapter Enclosure In Stock £30.84
FK1T StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £6.38
FK1T StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.33
FK1T StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £16.17
FK1T StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.55
FK1T StarTech.com Dual mSATA SSD to 2.5" SATA RAID Adapter Converter In Stock £35.55
FK1T StarTech.com M.2 NGFF to SATA Adapter In Stock £21.11
FK1T StarTech.com 6" SATA Power Y Splitter Cable In Stock £6.62
FK1T StarTech.com 2.5" SSD/HDD Mounting Bracket In Stock £4.34
Power Supply: [N/A]
