StarTech.com 1U Rack Shelf - 10in
Quicklinx: CWSGWS00 Mfr#: CABSHELF1U10
Product Type: Rack shelf, Rack shelf
18 In Stock
£24.25 ex VAT
£29.10 inc VAT
Add a sturdy, 1U server rack shelf into almost any rack or cabinet. This 1U rack shelf lets you add 10 in. of flat storage space to any EIA-310 compliant server rack or cabinet.
The durable fixed-rack shelf can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room or any other location with limited space available.
You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools.
  • Ensure your equipment is secure
  • Make the most of your available space
  • Customize your setup
    You can install the 1U rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools. The CABSHELF1U10 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 1U Fixed Server Rack Mount Shelf, 10in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 44lbs Weight Capacity, 10" Deep - 1U Network Rack Shelf (CABSHELF1U10) - rack shelf - 1U
Rack shelf
Package Content
4 cage nuts, 4 mounting screws
Rack Size
10"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
48.26 cm x 25.4 cm x 4.45 cm
Cantilever
Rack shelf
Product Material
Cold-rolled steel
Package Content
Rack Size
10"
Height (Rack Units)
1U
48.26 cm
25.4 cm
4.45 cm
Weight Limit
20 kg
Mounting Kit
Included
Cantilever
Limited warranty: - lifetime
CWSG StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
CWSG StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
CWSG StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.39
CWSG StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £34.53
CWSG StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
CWSG StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
CWSG StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
CWSG StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
CWSG StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £77.10
CWSG StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £92.81
CWSG StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.50
CWSG StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £53.98
CWSG StarTech.com Vented 1U Rack Shelf - 7in In Stock £23.86
CWSG StarTech.com 1U Rack Shelf - 10in In Stock £24.25
CWSG StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.81
CWSG StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.11
CWSG StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £38.94
CWSG StarTech.com 2 Post Server Rack Shelf - Center Mount - Black In Stock £57.46
CWSG StarTech.com 1U Vented Shelf 12in In Stock £33.68
CWSG StarTech.com 1U Vented Shelf 20in In Stock £55.10
CWSG StarTech.com 2U Vented Shelf 14in In Stock £61.91
CWSG StarTech.com 2U Vented Shelf 20in In Stock £73.78
