Add a sturdy, 1U server rack shelf into almost any rack or cabinet. This 1U rack shelf lets you add 10 in. of flat storage space to any EIA-310 compliant server rack or cabinet.
The durable fixed-rack shelf can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room or any other location with limited space available.
You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools.
Ensure your equipment is secure
The durable fixed-rack shelf can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel. -
Make the most of your available space
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room or any other location with limited space available. -
Customize your setup
You can install the 1U rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools. The CABSHELF1U10 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
- StarTech.com 1U Fixed Server Rack Mount Shelf, 10in Deep Steel Universal Cantilever Tray for 19" AV/Data/Network Equipment Rack with Cage Nuts & Screws, 44lbs Weight Capacity, 10" Deep - 1U Network Rack Shelf (CABSHELF1U10) - rack shelf - 1U
- Product Type
- Rack shelf
- Package Content
- 4 cage nuts, 4 mounting screws
- Black
- Rack Size
- 10"
- Height (Rack Units)
- 1U
- Product Material
- Cold-rolled steel
- 48.26 cm x 25.4 cm x 4.45 cm
- Cantilever
- Limited lifetime warranty
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Package Content
- Rack Size
- 10"
- 1U
- 48.26 cm
- 25.4 cm
- 4.45 cm
- Black
- Weight Limit
- 20 kg
- Mounting Kit
- Included
- Cantilever
- Limited warranty: - lifetime
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £31.58 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £32.14 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.75 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £56.01 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £59.25 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £77.01 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £85.53 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £55.64 |
StarTech.com Vented 1U Rack Shelf - 7in | In Stock | £25.50 |
StarTech.com 1U Rack Shelf - 10in | In Stock | £25.91 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £32.78 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £21.83 |
StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant | In Stock | £41.60 |
StarTech.com 2 Post Server Rack Shelf - Center Mount - Black | In Stock | £63.59 |
StarTech.com 1U Vented Shelf 12in | In Stock | £35.70 |
StarTech.com 1U Vented Shelf 20in | In Stock | £58.88 |
StarTech.com 2-Pack 1U Rack Shelf, Vented | In Stock | £58.56 |
