Add a high capacity, adjustable depth vented shelf into almost any server rack or cabinet. The ADJSHELFHDV 1U Adjustable Heavy Duty Vented Rack Mount Shelf lets you add a high-capacity, adjustable 1U shelf to virtually any standard 19-inch server rack or cabinet.
This heavy duty rackmount shelf can be adjusted from 19.5in to 38in (mounting depth) to fit your rack, while the vented design improves air flow and help to lower temperatures in the rack. Constructed using 1.2mm SPCC commercial grade cold-rolled steel, providing the ability to hold up to 113kg (250lbs) of equipment - a durable solution for storing large, non-rackmount pieces of equipment, heavy tools or peripherals in your rack or cabinet.
- StarTech.com Server Rack Shelf - 1U - Adjustable Mount Depth - Heavy Duty - rack shelf - 1U
- Product Type
- Rack shelf
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 1U
- Product Material
- Cold-rolled steel
- 48.2 cm x 70 cm x 4.37 cm
- 5.4 kg
- Adjustable depth, vented
- Limited lifetime warranty
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Rack Size
- 19"
- 1U
- 48.2 cm
- 70 cm
- 4.37 cm
- 5.4 kg
- Black
- Weight Limit
- 150 kg
- Mounting Kit
- Included
- RoHS
- Limited warranty: - lifetime
- Designed For
- P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £100.06 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £13.74 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £35.49 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.25 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.50 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £62.33 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £66.40 |
StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg | In Stock | £92.59 |
StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails | In Stock | £68.93 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £77.15 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £95.41 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £57.09 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £45.90 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £39.69 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £54.03 |
StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg | In Stock | £173.10 |
StarTech.com Vented 1U Rack Shelf - 7in | In Stock | £23.86 |
StarTech.com 1U Rack Shelf - 10in | In Stock | £24.25 |
StarTech.com Vented 1U Rack Shelf - 16 in. | In Stock | £32.16 |
StarTech.com Vented 1U Rack Shelf - 10in | In Stock | £21.14 |
StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant | In Stock | £39.36 |
StarTech.com 1U Vented Shelf 12in | In Stock | £34.43 |
StarTech.com 1U Vented Shelf 20in | In Stock | £55.10 |
StarTech.com 2U Vented Shelf 14in | In Stock | £61.91 |
StarTech.com 2U Vented Shelf 20in | In Stock | £73.74 |
StarTech.com 2-Pack 1U Rack Shelf, Vented | In Stock | £69.15 |
