StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg
Quicklinx: 8871WS00 Mfr#: ADJSHELFHD
Product Type: Rack shelf, Rack shelf
38 In Stock
£71.34 ex VAT
£85.60 inc VAT
Add a high capacity, adjustable depth fixed shelf into almost any server rack or cabinet. The ADJSHELFHD 1U Adjustable Heavy Duty Fixed Rack Mount Shelf lets you add a high-capacity, adjustable 1U shelf to virtually any standard 19-inch server rack or cabinet.
This heavy duty rackmount shelf can be adjusted from 19.5in to 38in (mounting depth) to fit your rack. Constructed using 1.0mm SPCC commercial grade cold-rolled steel, providing the ability to hold up to 80kg (175lbs) of equipment - a durable solution for storing large, non-rackmount pieces of equipment, heavy tools or peripherals in your rack or cabinet.
  • Durable construction
    Made from cold-rolled steel, this rack shelf is designed for long-term use, ensuring it can withstand the weight of various AV equipment.
  • Adjustable depth
    The adjustable depth feature allows the shelf to fit into different rack sizes, ranging from 19.5 to 38 inches, providing flexibility for various setups.
  • Weight capacity
    With a weight limit of 79.6 kg, this shelf supports a range of equipment, giving users confidence in its strength.
  • Easy installation
    The included mounting kit facilitates a quick and easy installation process, allowing for immediate setup in any server rack.
  • Environmentally compliant
    This product meets RoHS standards, ensuring it adheres to safety and environmental regulations.
StarTech.com 1U Adjustable Server Rack Mount Shelf - 175lbs - 19.5 to 38in Deep Universal Tray for 19" AV, Data & Network Equipment Rack (ADJSHELFHD) - rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
48.2 cm x 70 cm x 4.37 cm
4.9 kg
Adjustable depth
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
1U
48.2 cm
70 cm
4.37 cm
4.9 kg
Weight Limit
79.6 kg
Mounting Kit
Included
Adjustable depth
RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
8871 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £92.31
8871 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
8871 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
8871 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.39
8871 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.71
8871 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
8871 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
8871 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £89.04
8871 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £84.75
8871 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £61.35
8871 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £71.34
8871 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
8871 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.20
8871 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
8871 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
8871 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £154.86
8871 StarTech.com Vented 1U Rack Shelf - 7in In Stock £24.16
8871 StarTech.com 1U Rack Shelf - 10in In Stock £24.54
8871 StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.05
8871 StarTech.com Vented 1U Rack Shelf - 10in In Stock £20.54
8871 StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.40
8871 StarTech.com 1U Vented Shelf 12in In Stock £33.59
8871 StarTech.com 1U Vented Shelf 20in In Stock £54.90
8871 StarTech.com 2U Vented Shelf 14in In Stock £61.21
8871 StarTech.com 2U Vented Shelf 20in In Stock £70.33
8871 StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £54.63
