Quicklinx: GTBTWS00 Mfr#: SHELF-1U-12-FIXED-V
17 In Stock
£33.59 ex VAT
£40.30 inc VAT
1U Vented Server Rack Cabinet Shelf, 12in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf (SHELF-1U-12-FIXED-V).
  • Robust construction
    Crafted from SPCC cold rolled steel, this 1U vented server rack cabinet shelf offers a durable solution for mounting your AV, data, and network equipment securely within a 19" rack enclosure. Its sturdy build ensures long-term reliability and performance for your critical infrastructure.
  • Efficient cooling
    Featuring a vented design, this rackmount shelf promotes better air circulation around your equipment. This helps in maintaining optimal operating temperatures, reducing the risk of overheating and ensuring your systems run efficiently.
  • Easy installation
    Included with 4 M6 cage screws, 4 M6 square cage nuts, and 4 plastic washers, this 12 in deep fixed cantilever tray is designed for a hassle-free setup. Its compatibility with standard 19" AV, data, and network equipment enclosures makes it a versatile addition to any server room or data center.
StarTech.com 1U Vented Server Rack Cabinet Shelf, 12in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 55lbs Weight Capacity - 1U Network Rack Shelf - rack shelf - 1U
Rack shelf
Package Content
4 plastic washers, 4 M6 cage screws, 4 M6 square cage nuts
Rack Size
19"
Height (Rack Units)
1U
Product Material
48.3 cm x 30.5 cm x 4.3 cm
2.2 kg
Vented
Rack shelf
Product Material
Package Content
Rack Size
19"
Height (Rack Units)
1U
48.3 cm
30.5 cm
4.3 cm
2.2 kg
37 cm x 55 cm x 12 cm / 3 kg
Weight Limit
25 kg
Vented
EIA-310, ECA-310
Limited warranty: - lifetime
GTBT StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
GTBT StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
GTBT StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.99
GTBT StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
GTBT StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
GTBT StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.05
GTBT StarTech.com 1U Vented Shelf 20in In Stock £54.90
GTBT StarTech.com 2U Vented Shelf 14in In Stock £61.21
GTBT StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £54.63
