StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg
Quicklinx: 8875WS00 Mfr#: ADJSHELFHDV
Product Type: Rack shelf, Rack shelf
£82.73 ex VAT
£99.27 inc VAT
Add a high capacity, adjustable depth vented shelf into almost any server rack or cabinet. The ADJSHELFHDV 1U Adjustable Heavy Duty Vented Rack Mount Shelf lets you add a high-capacity, adjustable 1U shelf to virtually any standard 19-inch server rack or cabinet.
This heavy duty rackmount shelf can be adjusted from 19.5in to 38in (mounting depth) to fit your rack, while the vented design improves air flow and help to lower temperatures in the rack. Constructed using 1.2mm SPCC commercial grade cold-rolled steel, providing the ability to hold up to 113kg (250lbs) of equipment - a durable solution for storing large, non-rackmount pieces of equipment, heavy tools or peripherals in your rack or cabinet.
  • Robust Material
    This rack shelf is constructed from cold-rolled steel, ensuring strength and durability for reliable support of your equipment.
  • Adjustable Design
    The adjustable depth feature allows for custom fitting in various rack setups, accommodating different equipment sizes effortlessly.
  • Efficient Ventilation
    The vented design promotes airflow, helping to keep devices cool and preventing overheating during operation.
  • Substantial Weight Capacity
    Designed to hold up to 150 kg, this shelf provides peace of mind when storing heavy equipment without compromising stability.
  • Easy Installation
    The included mounting kit simplifies the installation process, making setup quick and straightforward for any 19-inch rack.
StarTech.com Server Rack Shelf - 1U - Adjustable Mount Depth - Heavy Duty - rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
48.2 cm x 70 cm x 4.37 cm
5.4 kg
Adjustable depth, vented
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
1U
48.2 cm
70 cm
4.37 cm
5.4 kg
Weight Limit
150 kg
Mounting Kit
Included
RoHS
Limited warranty: - lifetime
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKQMCAB12
8875 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £96.93
8875 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
8875 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.00
8875 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
8875 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.01
8875 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
8875 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
8875 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £92.13
8875 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.73
8875 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £63.29
8875 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £73.91
8875 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £82.73
8875 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
8875 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.71
8875 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £38.06
8875 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £52.08
8875 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £159.07
8875 StarTech.com Vented 1U Rack Shelf - 7in In Stock £24.16
8875 StarTech.com 1U Rack Shelf - 10in In Stock £24.54
8875 StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £32.11
8875 StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.28
8875 StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.40
8875 StarTech.com 1U Vented Shelf 12in In Stock £34.09
8875 StarTech.com 1U Vented Shelf 20in In Stock £54.90
8875 StarTech.com 2U Vented Shelf 14in In Stock £61.70
8875 StarTech.com 2U Vented Shelf 20in In Stock £73.11
8875 StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £56.46
