Connect your USB Type-C devices to your laptop or desktop computer. Need to connect your new USB-C mobile device to a computer with a traditional-style USB-A USB port? This 1m USB 2.0 USB-A to USB-C cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
Connect your newer mobile devices that feature a USB-C connector, such as the Nokia N1 tablet to your computer, with data transfer speeds of 480 Mbps.
The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage.
Charge and sync your USB Type-C mobile devices
Connect your newer mobile devices that feature a USB-C connector, such as the Samsung Galaxy S8, S8+, Nexus 6P, and 5X phones to your computer, with data transfer speeds of 480 Mbps. -
Connect with ease
The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage. The USB2AC1M from StarTech.com is backed by a lifetime warranty for guaranteed reliability.
- StarTech.com USB C to USB Cable - 3 ft / 1m - USB A to C - USB 2.0 Cable - USB Adapter Cable - USB Type C - USB-C Cable (USB2AC1M) - USB-C cable - 24 pin USB-C to USB - 1 m
- USB-C cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30C1A1CPD, HB30C3A1CFB, HB30C3A1CFBW, HB30C3A1CFS, HB30C3A1GE, HB30C3A1GEA, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, ST4200MINIC
- USB-C cable
- Technology
- Double shielded
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.72 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.68 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.37 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.11 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £16.66 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.23 |
StarTech.com USB-C to Micro-USB Adapter M/F | In Stock | £9.59 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.26 |
StarTech.com 0.5m USB 2.0 C to A Cable M/M | In Stock | £7.94 |
StarTech.com 1m USB A to C Cable - USB 2.0 | In Stock | £11.30 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £18.04 |
