Connect USB 2.0 devices to a USB hub or to your computer. The USB2AA1M 1-meter USB 2.0 cable features two USB ''A'' male connectors, delivering a dependable way to connect your PC to a USB hub, or connect USB 2.0 peripherals to a USB hub.
Reliable Connectivity
The cable features male connectors on both ends, ensuring a stable connection for data transfer between devices with USB Type-A ports. -
Compatible Standards
This cable complies with USB 2.0 standards, providing a transfer speed suitable for various peripherals and devices. -
Durable Construction
Designed with 24/28 AWG wire, this cable offers strength and flexibility, making it ideal for everyday use. -
Environmentally Friendly
The cable is compliant with RoHS standards, ensuring that it is manufactured without harmful substances.
- StarTech.com 1m USB 2.0 A to A Cable - M/M - 1m USB 2.0 aa Cable - USB a male to a male Cable (USB2AA1M) - USB cable - USB to USB - 1 m
- USB cable
- Length
- 1 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: ST4200MINI2, SV231HDMIUA
- USB cable
- American Wire Gauge (AWG)
- 24/28
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
