StarTech.com 1m USB 2.0 A to A Cable - M/M
Quicklinx: 7W8TWS00 Mfr#: USB2AA1M
Length: 1m
11 In Stock
£4.90 ex VAT
£5.88 inc VAT
Connect USB 2.0 devices to a USB hub or to your computer. The USB2AA1M 1-meter USB 2.0 cable features two USB ''A'' male connectors, delivering a dependable way to connect your PC to a USB hub, or connect USB 2.0 peripherals to a USB hub.
  • Reliable Connectivity
    The cable features male connectors on both ends, ensuring a stable connection for data transfer between devices with USB Type-A ports.
  • Compatible Standards
    This cable complies with USB 2.0 standards, providing a transfer speed suitable for various peripherals and devices.
  • Durable Construction
    Designed with 24/28 AWG wire, this cable offers strength and flexibility, making it ideal for everyday use.
  • Environmentally Friendly
    The cable is compliant with RoHS standards, ensuring that it is manufactured without harmful substances.
StarTech.com 1m USB 2.0 A to A Cable - M/M - 1m USB 2.0 aa Cable - USB a male to a male Cable (USB2AA1M) - USB cable - USB to USB - 1 m
USB cable
Length
1 m
Connector
4 pin USB Type A - male
Connector (Second End)
USB / USB 2.0
P/N: ST4200MINI2, SV231HDMIUA
USB cable
American Wire Gauge (AWG)
24/28
Length
1 m
Connector
USB / USB 2.0, RoHS
7W8T StarTech.com 1m USB 2.0 A to A Cable - M/M In Stock £4.90
7W8T StarTech.com 2m USB 2.0 A to A Cable - M/M In Stock £5.05
Length: 1m
