StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M
Quicklinx: BMPWWS00 Mfr#: USB31CC1M
Length: 1m
£13.42 ex VAT
£16.10 inc VAT
Connect your USB Type-C devices. Need to charge and sync your USB Type-C mobile devices or connect your newer USB 3.1 peripherals? This 1m USB-C to USB-C cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you sync your USB Type-C devices in no time at all.
Moving large files or transferring movies can be done in seconds, at twice the speed of USB 3.0 and 20x faster than USB 2.0 - all while charging your device with 60 Watts (3 Amp) power delivery.
You'll also be able to connect your USB 3.1 peripheral devices, such as hard drive enclosures and docks, to your laptop. Now you can spend less time transferring and backing up your data and more time focusing on your projects and presentations.
The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage.
Plus, the cable is backward compatible with previous USB devices.
This USB-C cable has been certified with USB-IF (USB Implementers Forum) in order to meet all USB 3.1 specifications. This includes all environmental, electrical and mechanical standards set by USB compliance. This ensures a high-quality, reliable cable for all your USB-C devices.
StarTech.com 1m / 3 ft USB-C Cable - M/M - USB 3.1 (10Gbps) - USB-C cable - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.1
Apple MacBook
USB-C cable
Double shielded
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
24 pin USB-C - male
USB 3.1, RoHS, USB-IF
Apple MacBook
BMPW StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.31
BMPW StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.41
BMPW StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.36
BMPW StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.42
BMPW StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £7.03
BMPW StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £12.59
BMPW StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.87
Length: 1m
Price Range Ex VAT: 0 - 50
