StarTech.com 1m USB 2.0 C to Micro-USB Cable
Quicklinx: BFP7WS00 Mfr#: USB2CUB1M
Length: 1m
30 In Stock
£7.73 ex VAT
£9.27 inc VAT
Charge and sync your USB 2.0 Micro-B devices from a USB-C host. Need to connect your Micro-USB 2.0 device to a newer USB Type-C laptop or desktop computer? This 1m USB Type-C to Micro-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
Charge and sync your older Micro-USB mobile devices, such as your tablet or phone, with newer computers at data transfer rates of up to 480 Mbps.
The cable can also be used to backup data to an external Micro-USB 2.0 hard drive from your USB-C or Thunderbolt 3 computer.
  • Reliable and versatile connection
    This USB C to Micro USB cable allows for seamless connectivity between USB-C and Micro USB devices. The 3 ft length offers flexibility in use, accommodating different setups.
  • Efficient data transfer
    Compliant with USB 2.0 standards, this cable facilitates quick data transfer, ensuring effective performance whether for charging or syncing devices.
  • Enhanced durability
    Constructed with nickel-plated connectors, this cable resists wear and tear over time, providing a reliable connection even with regular use.
StarTech.com USB C to Micro USB Cable - 3 ft / 1m - USB 2.0 Cable - Micro USB Cord - Micro B USB C Cable - USB 2.0 Type C (USB2CUB1M) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 1 m
USB-C cable
Shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30C3A1CFB, HB30C3A1CFS
USB-C cable
Shielded
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
BFP7 StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.73
BFP7 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
BFP7 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
BFP7 StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.56
BFP7 StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
BFP7 StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £10.31
BFP7 StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.97
BFP7 StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.01
BFP7 StarTech.com 2m USB 2.0 C to Micro B Cable In Stock £12.84
BFP7 StarTech.com 0.5m USB 2.0 C Micro-B Cable In Stock £8.08
BFP7 StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £17.57
Length: 1m
