StarTech.com 0.5m USB 2.0 C Micro-B Cable
Quicklinx: CZCLWS00 Mfr#: USB2CUB50CM
11 In Stock
£7.93 ex VAT
£9.51 inc VAT
Charge and sync your USB 2.0 Micro-B devices from a USB-C host, with reduced clutter. This USB-C to Micro-B cable lets you charge and sync your USB 2.0 Micro-USB mobile device from a USB Type-C laptop, USB-C wall charger, car charger or power bank.
The cable also lets you connect an external Micro-USB drive for easy data backups.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your Micro-USB mobile devices with your laptop.
You can also use the cable to charge your devices from a USB-C wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
The cable can also be used to back up data from your USB-C or Thunderbolt 3 computer to an external Micro-USB 2.0 drive. The short cable lets you set up in small offsite workspaces, or in a coffee shop or hotel room, so that you can install your equipment without excess cable getting in your way.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
  • Reliable performance
    This cable complies with USB 2.0 standards, ensuring efficient data transfer rates for daily tasks. It is suitable for connecting various devices without compromising speed.
  • Versatile connectivity
    Featuring a 24 pin USB-C connector and a 5 pin Micro-USB Type-B connector, this cable enables compatibility with a wide range of devices, making it a valuable addition to any tech setup.
StarTech.com USB C to Micro USB Cable - 0.5m - M/M - Thunderbolt 3 Compatible - Micro USB Cord -USB Type C to Micro USB Cable (USB2CUB50CM) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 50 cm
USB-C cable
Shielded
Sync and charge
Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
USB-C cable
Shielded
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Sync and charge
Length
50 cm
20 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE
CZCL StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.74
CZCL StarTech.com 2m USB 2.0 C to Micro B Cable In Stock £11.11
CZCL StarTech.com 0.5m USB 2.0 C Micro-B Cable In Stock £7.93
