StarTech.com 1m USB 2.0 USB-C to USB-B Cable
Quicklinx: BN4BWS00 Mfr#: USB2CB1M
Length: 1m
14 In Stock
£9.60 ex VAT
£11.52 inc VAT
Connect USB 2.0 USB-B devices to your USB-C host. Need to connect your USB-B device to a USB-C device? This 1m USB-C to USB-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
Connect your older USB 2.0 peripheral devices, such as your printer or external hard drive, to newer computers, with data transfer speeds of up to 480 Mbps.
  • Reliable connectivity
    The 24 pin USB-C connector ensures a solid link between devices, supporting efficient data communications without delays or interruptions.
  • Durable construction
    With nickel plating on connectors, this cable is designed to resist corrosion and wear, providing long-lasting performance.
  • Interference reduction
    The double shielded design minimizes signal interference, enhancing the overall quality of data transmission for uninterrupted printing tasks.
StarTech.com USB C to USB B Printer Cable - 3 ft / 1m - USB C Printer Cable - USB C to USB B Cable - USB Type C to Type B (USB2CB1M) - USB-C cable - 24 pin USB-C to USB Type B - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30C3A1CFB, HB30C3A1CFS
USB-C cable
Double shielded
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
BN4B StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.73
BN4B StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £7.96
BN4B StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.60
BN4B StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.07
BN4B StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.20
BN4B StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.63
BN4B StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.60
BN4B StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.00
BN4B StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.05
BN4B StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.44
BN4B StarTech.com 2m 6ft USB 2.0 C to B Cable In Stock £12.69
BN4B StarTech.com 2m 6ft USB 3.0 C to B Cable In Stock £12.71
BN4B StarTech.com 3m USB 2.0 C to B Cable In Stock £15.57
BN4B StarTech.com 0.5m USB 2.0 C to B Cable In Stock £8.41
BN4B StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.26
Length: 1m
