Connect your USB 3.0 devices with this high-quality USB 3.0 certified cable. The USB3CAB1M 1-meter USB 3.0 A-to-B cable provides a high quality connection between peripheral devices that feature a USB 3.0 type-B port, such as hard drive enclosures, card readers, docking stations and video capture devices and a USB-capable computer.
This cable is USB-IF certified to USB 3.0 specifications, guaranteeing a dependable, long-lasting connection to your USB ''B'' devices.
Reliable connection
This USB 3.0 cable features nickel-plated connectors that provide a secure and stable connection, enhancing overall performance and lifespan. -
Fast data transfer
With a data transfer rate of 5 Gbps, this cable allows users to move large files quickly and efficiently between devices. -
Durable design
The molded construction of the cable includes a strain relief feature, ensuring that it withstands everyday wear and tear while maintaining performance. -
Versatile compatibility
Designed with a 9-pin USB Type-B and USB Type-A male connectors, this cable is compatible with a wide range of devices including printers, external drives, and more. -
Environmentally conscious
This cable complies with RoHS and USB-IF standards, making it a responsible choice for environmentally aware consumers.
- StarTech.com 1m 3 ft Certified SuperSpeed USB 3.0 A to B Cable Cord - USB 3 Cable - 1x USB 3.0 A (M), 1x USB 3.0 B (M) - 1 meter, Black (USB3CAB1M) - USB cable - USB Type B to USB Type A - 1 m
- USB cable
- Technology
- Double shielded
- Molded, strain relief, 5 Gbps data rate
- Length
- 1 m
- Connector
- 9 pin USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: HB30A4AIB, HB30AM4AB, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HB31C4AB, HBS304A24A, KITBXDOCKPNA, KITBXDOCKPUK, S351BMU33ET, S351BMU33ETG, S351BU313, S3520BU33ER, S352BU313R, S352BU33HR, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB 3.0, RoHS, USB-IF
- Designed For
- P/N: HB30A4AIB, HB30AM4AB, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HB31C4AB, HBS304A24A, KITBXDOCKPNA, KITBXDOCKPUK, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, S351BU313, S3520BU33ER, S352BU313R, S352BU33HR, SDOCK2U313R, SDOCKU313, SDOCKU313E, SDOCKU33EF, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M
