Connect your USB 3.0 devices, with this high-quality USB 3.0 certified cable. The USB3CAB2M 2-meter USB 3.0 A-to-B cable provides a high quality connection between peripheral devices that feature a USB 3.0 type-B port, such as hard drive enclosures, card readers, docking stations and video capture devices and a USB-capable computer.
This cable is USB-IF certified to USB 3.0 specifications, guaranteeing a dependable, long-lasting connection to your USB ''B'' devices.
Efficient data transfer
This cable supports a data rate of 5 Gbps, allowing for quick and efficient file transfers between devices. -
Shielded construction
The shielded design helps reduce interference, ensuring reliable performance during data transfer. -
Durable molded connectors
Molded connectors enhance the durability of this cable, making it suitable for everyday use. -
Corrosion-resistant connectors
Nickel-plated connectors provide improved conductivity and resistance to corrosion, ensuring a longer lifespan. -
Compliance with standards
This cable is compliant with USB 3.0 and RoHS standards, ensuring quality and environmental responsibility.
- StarTech 2m 6 ft Certified SuperSpeed USB 3.0 A to B Cable Cord - USB 3 Cable - 1x USB 3.0 A (M), 1x USB 3.0 B (M) - 2 meter, Black (USB3CAB2M) - USB cable - USB Type B to USB Type A - 2 m
- USB cable
- Technology
- Shielded
- Molded, 5 Gbps data rate
- Cable Length
- 2 m
- Connector
- 9 pin USB Type B - male
- Connector (Second End)
- 9 pin USB Type A - male
- USB 3.0
- Black
- Designed For
- P/N: HBS304A24A, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, S3510BMU33, S3510SMU33, S351BMU33ET, S351BMU33ETG, S3520BU33ER, S352BU33HR, SDOCKU33EF, SV231DHU34K6, SV231HU34K6, SV231QDPU34K, SV431HU34K6
- USB cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/28
- Plated Connector
- Nickel
- Cable Length
- 2 m
- Black
- Connector
- USB 3.0, RoHS
- Designed For
