StarTech.com 15U Wall Mount Server Rack
Quicklinx: D332WS00 Mfr#: RK15WALLO
£78.45 ex VAT
£94.14 inc VAT
This open-frame wall-mount server rack provides 15U of storage, allowing you to save space and stay organized. The equipment rack can hold up to 198 lb. (90 kg).
The network rack is 12 in. (30.4 cm) deep, so it's perfect for smaller spaces. It's easy to assemble and features mounting holes that are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common wall-frame stud spacing. The wall-mount rack comes in a flat-pack making it easy to transport and reducing your cost in shipping.
You can mount the open-frame rack where space is limited, such as on a server room wall, office, or above a doorway, to expand your workspace and ensure your equipment is easy to access.
By having an open frame the server rack provides passive cooling to equipment. Additionally, the open frame provides easy access and configurability to your equipment, allowing you to maximize productivity.
  • Easy, hassle-free installation
  • Free up space
  • Keep your equipment cool and accessible
    By having an open frame the server rack provides passive cooling to equipment. Additionally, the open frame provides easy access and configurability to your equipment, allowing you to maximize productivity. The RK15WALLO is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com 15U 19" Wall Mount Network Rack - 12" Deep 2 Post Open Frame Server Room Rack for Data/AV/IT/Computer Equipment/Patch Panel with Cage Nuts & Screws 200lb Capacity, Black (RK15WALLO) - rack - 15U
Rack
Placing / Mounting
Wall mountable
Package Content
2 vertical rails, 16 assembly screws, 2 horizontal brackets, 60 M6 cage nuts, 60 M6 screws, 60 washers
Rack Size
12"
Height (Rack Units)
15U
Product Material
Steel
50.4 cm x 30.5 cm x 77.5 cm
12.5 kg
2 post
5-year warranty
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
12"
Height (Rack Units)
15U
50.4 cm
30.5 cm
77.5 cm
12.5 kg
Inner Dimensions
46.5 cm x 29.2 cm x 66.8 cm
Weight Limit
90 kg
2 post
Limited warranty: - 5 years
D332 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
D332 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
D332 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
D332 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
D332 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
D332 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
D332 StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
D332 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
D332 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
D332 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
D332 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
D332 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
D332 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
D332 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.48
D332 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
D332 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
D332 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
D332 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
D332 StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
D332 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
D332 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
D332 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
D332 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
D332 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
D332 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
D332 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
D332 StarTech.com 19in Cable Management Panel In Stock £24.18
D332 StarTech.com 12U Wall Mount Server Rack In Stock £66.02
D332 StarTech.com 15U Wall Mount Server Rack In Stock £78.45
D332 StarTech.com 15U Wall-Mount Server Rack In Stock £113.87
D332 StarTech.com 12U Wall-Mount Server Rack In Stock £102.53
D332 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
