Organize cables in your server rack or cabinet with a horizontal, covered cable duct. The CMDUCT2U 2U Finger Duct Cable Management Panel mounts to a standard 19" 2 or 4-post rack to help you organize horizontal cabling, through a covered cable duct.
The 2U cable organizer features a removable top cover that makes it easy to add or remove bundled cables quickly. The duct also offers a series of fingers on either side, as well as pass-through holes at the back to help you route your cables where you need them, and reduce cable strain in the process.
Made of high-quality steel, the cable manager is a durable solution for your server room or wiring closet. For easy installation, this horizontal cable organizer comes complete with 2 sets of rack screws (M5 and M6).
 - StarTech.com Horizontal 2U Server Rack Cable Management Finger Duct w/ Cover - 19" Network Rack Wire Duct Raceway Panel - Slotted Wire Duct (CMDUCT2U) - rack cable management panel - 2U
- Product Type
 - Rack cable management panel
 - Black
- Rack Size
 - 19"
- Height (Rack Units)
 - 2U
- Product Material
 - Steel
 - 48.2 cm x 7.9 cm x 8.81 cm
 - 860 g
 - 2-year warranty
- Designed For
 - P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RK1224WALHM, RK1232WALHM, RK1233BKM, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2433BKM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2
- Product Type
- Product Material
 - Steel
- Rack Size
 - 19"
 - 2U
 - 48.2 cm
 - 7.9 cm
 - 8.81 cm
 - 860 g
 - Black
- Mounting Kit
 - Included
 - RoHS
 - Limited warranty: - 2 years
- Designed For
 - P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RK1219SIDEM, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
                        StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.20 |
                        StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.24 |
                        StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.31 |
                        StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £22.90 |
