Add a cable management hook to your server rack or cabinet for strain relief and organization. The CMHOOK1U Vertical Cable Management D-ring lets you add a 1U metal cable hook to your server rack or cabinet to provide an organized channel for your cables. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Constructed of high-quality steel, the cable D-ring measures 2.2 x 3.9in (5.7 x 10cm) and offers a flexible opening for easy insertion of bundled cables. Providing strain relief for attached cables, multiple cable rings can be attached to your rack where you need them for a versatile cable management solution.
Durable material
Made from steel, this cable management ring is designed to withstand the demands of a busy server environment, ensuring reliability over time. -
Efficient design
Featuring a height of 1 rack unit, this management ring can be integrated into existing server racks, optimizing space while ensuring accessibility.
 - StarTech.com 1U Vertical 2.2 x 3.9in Server Rack Cable Management D-Ring Hook w/ Flexible Opening - Network Rack-Mount Cord Organizer Ring (CMHOOK1U) - cable management ring - 1U
- Product Type
 - Cable management ring
 - Black
- Height (Rack Units)
 - 1U
- Product Material
 - Steel
 - 10.13 cm 5.7 cm
 - 82 g
 - 2-year warranty
- Designed For
 - P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12V2
- Product Type
- Product Material
 - Steel
 - 1U
 - 10.13 cm
 - 5.7 cm
 - 82 g
 - Black
 - RoHS
 - Limited warranty: - 2 years
- Designed For
 - P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK1219SIDEM, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK920WALM, RK960CP, RK9WALM, RKCONS1708K, RKCONS1716K, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
                        StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
                        StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.21 |
                        StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) | In Stock | £6.20 |
                        StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £38.24 |
                        StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
                        StarTech.com 100ft. Hook-and-Loop Cable Tie | In Stock | £17.53 |
                        StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable | In Stock | £17.51 |
                        StarTech.com Rack Cable Management D-Ring | In Stock | £14.82 |
