Extend the distance between a computer and a USB 2.0 device by 10 meters. The USB2AAEXT10M 10m Active USB 2.0 Extension Cable offers one USB-A male connector and one USB-A female connector, and provides an active extension of USB 2.0 devices of up to 10-meters (30-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables.
Up to 4 of these cables can be daisy-chained together, allowing for a total USB extension of up to 40-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter (provided with the cable).
The USB2AAEXT10M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
Reliable connectivity
The cable utilizes active technology to regenerate signals, allowing for consistent data transfer over longer distances without degradation. -
Versatile compatibility
With USB Type-A connectors on both ends, this extension cable is suitable for a wide range of devices including printers and external storage. -
High-quality construction
Constructed with shielded materials and nickel-plated connectors, this cable ensures a reliable and stable connection compared to standard cables. -
Standards compliance
The cable meets USB 2.0 standards and is compliant with FCC and RoHS regulations, ensuring safety and reliability in use.
- StarTech.com 10m USB 2.0 Active Extension Cable M/F - 10 meter USB 2.0 Repeater / Extender Cable USB A (M) to USB A (F) 10 m Black - 3 ft (USB2AAEXT10M) - USB extension cable - USB to USB - 10 m
- Technology
- Shielded
- Active cable (signal regeneration)
- Length
- 10 m
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: LTUB1MBK, SVA5H2NEUA, UUSBOTG
- Technology
- Shielded
- Plated Connector
- Nickel
- Length
- 10 m
- Black
- Connector
- USB / USB 2.0, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.02 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.29 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £60.03 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.46 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £51.00 |
StarTech.com 25m USB 2.0 Active Extension Cable - M/F | In Stock | £90.27 |
StarTech.com 5m USB 2.0 Active Extension Cable - M/F | In Stock | £37.03 |
