StarTech.com 10GBase-T Adapter w/ USB-C Cable
Quicklinx: DXG0WS00 Mfr#: TB310G
Add high-speed wired 10G Ethernet network connectivity to your Thunderbolt 3 enabled desktop or laptop computer. This Thunderbolt 3 to 10Gb Ethernet adapter connects Thunderbolt 3 enabled devices to a wired Ethernet network, with support for 10Gb/s, 5Gb/s, 2.5Gb/s, 1Gb/s and 100Mb/s Base-T speeds.
Increase your data transfer speeds by harnessing the performance of Thunderbolt 3. This Ethernet adapter adds a single RJ45 Ethernet port with 10 Gigabit support to help easily access very large files over the network at increased 10Gbps speeds.
The 5-speed Thunderbolt 3 to 10GbE adapter uses premium chipsets, providing a low-power, high-performance NBASE-T solution. The 10GBASE-T standard supports 10Gbps speeds over existing CAT6a or better cabling at distances of up to 100 m. The Tehuti TN4010 controller chipset is compliant with 802.3az Energy Efficient Ethernet and ensures peak operating efficiency with reduced power consumption in bandwidth-intensive workstation applications.
This Thunderbolt 3 NIC is an easy addition to any modern workstation. Taking up only 12 square inches of desk space and fully bus-powered, it's extremely portable with a small footprint. The fanless design means the adapter is noiseless (0dB), so you can set up in an open office space without being disruptive. It's ideal for virtually any type of workspace or environment, including remote desks and modern open-concept offices.
StarTech.com Thunderbolt 3 to 10GBase-T Ethernet Adapter - Multi Gigabit Network Adapter - USB Type C Connector (TB310G) - network adapter - Thunderbolt 3 - 1/2.5/5/10GBase-T x 1 - TAA Compliant
Network adapter
External
Interface (Bus) Type
Thunderbolt 3
Ports
7.5 cm x 10.2 cm x 2.9 cm
350 g
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
Data Transfer Rate
7.5 Gbps
Jumbo frame size: 9000
Intel / Tehuti / Marvell DSL6340 / TN4010 / 88X3310PA1
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ad (LACP), IEEE 802.3an
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Apple MacOS X 10.11 - 10.14
TAA Compliant
Network adapter
External
Thunderbolt 3
Ports
Wired
Cabling Type
Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 5 Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
7.5 Gbps
Status Indicators
Link/activity, connection status
Auto-negotiation, auto-uplink (auto MDI/MDI-X), promiscuous mode
Processor / Memory
1 x 10GBase-T - RJ-45 - female , 1 x Thunderbolt 3 - 24 pin USB-C - female
1 x Thunderbolt 3 / USB-C cable (external)
FCC, RoHS, WEEE, RCM
TAA Compliant
7.5 cm
10.2 cm
2.9 cm
350 g
Shipping Weight
450 g
5 °C
35 °C
20 - 80%
