StarTech.com 10GBase-BX SFP+ - Downstream
Quicklinx: D1VMWS00 Mfr#: SFP10GBBXDST
Add reliable and cost-effective 10 Gigabit Ethernet connections over single-mode fiber, with this SFP+ module. This 10GBase-BX (downstream) SFP+ module delivers what you need most in your network connections: reliable performance. It's built to exacting MSA specifications and fully tested to ensure seamless compatibility. The single-mode SFP+ transceiver module offers a cost-effective way to add, replace or upgrade the ports on your networking equipment.
With data transfer rates of up to 10Gbps and support for Digital Diagnostics Monitoring (DDM / DOM), this LC SFP module can be installed into fiber networking equipment with an MSA compliant port. It delivers dependable 10 Gigabit connectivity over single-mode fiber for 10GBase-BX compliant networks, with a maximum distance of up to 10 km (6.2 mi.) and 1330nm Tx / 1270nm Rx optical wavelength.
This optical transceiver is engineered to meet or exceed the industry's MSA (Multi-Source Agreement) standards. StarTech.com brings its established reputation for high-quality connectivity solutions to SFP transceivers, providing SFPs that match major OEM brands in performance and reliability. Committed to the highest standards, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile solution that's compatible with a wide range of networking equipment, allowing you to expand your network to remote segments cost-effectively.
StarTech.com MSA Uncoded SFP+ Module, 10GBASE-BX, 10 Gigabit Ethernet Bi-Directional (BiDi) Fiber Single Strand SFP+ Transceiver, LC 10km , Mini GBIC Transceiver SFP+ Module, Downstream - Lifetime Warranty (SFP10GBBXDST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-BX
Data Transfer Rate
10 Gbps
Optical Wave Length
1330 (TX) / 1270 (RX) nm
10GbE
Max Transfer Distance
10 km
1.39 cm x 5.84 cm x 1.26 cm
30 g
Plug-in module
Silver
Wired
Cabling Type
10GBase-BX
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
10 km
Digital Optical Monitoring (DOM) support, Digital Diagnostics Monitoring (DDM)
IEEE 802.3ae
1 x Ethernet 10GBase-BX - LC single-mode
cUL, FCC, RoHS, WEEE, MSA
1.39 cm
5.84 cm
1.26 cm
30 g
Limited warranty - lifetime
70 °C
5 - 95%
D1VM StarTech.com 7m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £24.49
D1VM StarTech.com 10m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £26.56
D1VM StarTech.com 1m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £19.89
D1VM StarTech.com 4m Single Mode Duplex Fiber Patch Cable LC-LC In Stock £22.15
D1VM StarTech.com 2-Port 10G Fiber NIC-Open SFP+ In Stock £307.47
