Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 10ft long cable. The DP2VGAMM10B 10ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your new Mini DisplayPort computer to work with an older VGA monitor or projector.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 10 ft DisplayPort to VGA Adapter Cable - DP to VGA Video Converter - Active DisplayPort to VGA Cable for PC 1920x1200 - Black (DP2VGAMM10B) - DisplayPort cable - 3.05 m
- DisplayPort cable
- Latched
- Length
- 3.05 m
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - male
- FCC, RoHS
- Black
- 3-year warranty
- DisplayPort cable
- Latched
- Length
- 3.05 m
- Black
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - male
- FCC, RoHS
- 3-year warranty
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £22.02 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £17.08 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £18.06 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £17.24 |
StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £19.46 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.51 |
StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £7.03 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £14.91 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £19.30 |
StarTech.com DisplayPort to VGA Adapter - 1920x1200 | In Stock | £63.99 |
