Connect a DisplayPort-equipped PC to a nearby VGA monitor/Projector, with a short 3 foot cable. The DP2VGAMM3B active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a nearby VGA monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
High resolution support
The cable supports a maximum output resolution of 2048 x 1280, ensuring sharp images across multiple displays. -
Active cable technology
Designed as an active cable, it boosts signal quality over longer distances, reducing the risk of image degradation. -
Smooth refresh rate
With a refresh rate of 60 Hz, this adapter cable delivers fluid motion and reduces lag during video playback or gaming. -
Compliance and safety
Adheres to FCC and RoHS standards for safe and reliable performance, ensuring compatibility with a range of devices. -
Secure connection design
Features latched connectors that provide a secure fit, maintaining a stable connection during use.
- StarTech.com 3ft DisplayPort to VGA Adapter Cable - 1920x1200 - Active DisplayPort (DP) Computer or Laptop to VGA Monitor or TV Display (DP2VGAMM3B) - video adapter cable - DisplayPort to HD-15 (VGA) - 1 m
- Video adapter cable
- Active cable, 2048 x 1280 support 60Hz, HBR2 support
- Length
- 1 m
- Connector
- 20 pin DisplayPort - male - latched
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - male
- DisplayPort 1.2
- Black
- 3-year warranty
- Length
- 1 m
- Black
- 79 g
- Connector
- DisplayPort 1.2, FCC, RoHS, EDID compatible
- Shipping Width
- 16 cm
- Shipping Depth
- 24 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 90 g
- 3-year warranty
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £21.02 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £17.08 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £18.06 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £17.24 |
StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £19.46 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.51 |
StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £7.03 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £14.91 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £19.30 |
StarTech.com DisplayPort to VGA Adapter - 1920x1200 | In Stock | £63.99 |
