StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
Quicklinx: 907YWS00 Mfr#: DP2VGAMM6B
More than 50 In Stock
£21.98 ex VAT
£26.37 inc VAT
Connect a DisplayPort-equipped PC to a VGA monitor/projector, with a 6ft cable. The DP2VGAMM6B 6ft active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector with no additional adapters or cables required - a cost-effective solution for enabling your new Mini DisplayPort computer to work with an older VGA monitor or projector.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 6ft DisplayPort to VGA Cable - 1920 x 1200 - Active DP to VGA Adapter - DP to VGA Monitor Cable (DP2VGAMM6B) - DisplayPort cable - 1.83 m
DisplayPort cable
Latched
Length
1.83 m
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - male
FCC, RoHS
3-year warranty
DisplayPort cable
Latched
Length
1.83 m
Connector
20 pin DisplayPort - male
FCC, RoHS
3-year warranty
907Y StarTech.com Slimline Adapter HDDB15 F/F In Stock £5.10
907Y StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £24.40
907Y StarTech.com Right Angle VGA to VGA Cable Adapter Type 2 - M/F In Stock £7.01
907Y StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £16.02
907Y StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F In Stock £13.32
907Y StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.83
907Y StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £21.98
907Y StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £23.68
907Y StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £6.99
907Y StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.13
907Y StarTech.com DP to VGA Adapter with Audio In Stock £6.96
907Y StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £70.60
