StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km
Quicklinx: 6BDDWS00 Mfr#: MCM110ST2GB
30 In Stock
£64.74 ex VAT
£77.68 inc VAT
This Ethernet to MM Fiber Media Converter creates a cost-effective Ethernet to fiber link, transparently converting to/from 10Base-T or 100Base-Tx Ethernet signals and 100Base-Fx optical signals to extend an Ethernet network connection over a multimode fiber backbone.
The converter supports a maximum multimode fiber optic cable distance of 2km (1.2 miles), providing a simple solution for connecting 10Base-T/100Base-Tx Ethernet networks to remote locations using ST-terminated multimode fiber, while delivering solid network performance and scalability.
Easy to setup and install, this compact, value-conscious media converter features auto-switching MDI and MDI-X support on the RJ45 UTP connections as well as manual controls for UTP mode, speed, Full and Half Duplex, as well as LFP (Link Fault pass-through) on/off.
StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / ST multi-mode
External
United Kingdom
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
7.3 cm x 9.7 cm x 2.3 cm
90 g
1-year warranty
External
United Kingdom
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Status Indicators
Port duplex mode, power, link/activity
Flow control, auto-negotiation, half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - ST multi-mode female x 2
FCC, RoHS
External power adapter
7.3 cm
9.7 cm
2.3 cm
90 g
Limited warranty - 1 year
50 °C
0 - 90%
6BDD StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km In Stock £60.49
6BDD StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km In Stock £64.74
6BDD StarTech.com DC Power Adapter - 12V, 2A In Stock £11.96
6BDD StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
Type: Media Converter
