StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km
Quicklinx: 6BDDWS00 Mfr#: MCM110ST2GB
30 left in stock
£64.74 ex VAT
£77.68 inc VAT
This Ethernet to MM Fiber Media Converter creates a cost-effective Ethernet to fiber link, transparently converting to/from 10Base-T or 100Base-Tx Ethernet signals and 100Base-Fx optical signals to extend an Ethernet network connection over a multimode fiber backbone.
The converter supports a maximum multimode fiber optic cable distance of 2km (1.2 miles), providing a simple solution for connecting 10Base-T/100Base-Tx Ethernet networks to remote locations using ST-terminated multimode fiber, while delivering solid network performance and scalability.
Easy to setup and install, this compact, value-conscious media converter features auto-switching MDI and MDI-X support on the RJ45 UTP connections as well as manual controls for UTP mode, speed, Full and Half Duplex, as well as LFP (Link Fault pass-through) on/off.
StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km - fibre media converter - 10Mb LAN, 100Mb LAN
Fibre media converter - RJ-45 / ST multi-mode
External
United Kingdom
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
7.3 cm x 9.7 cm x 2.3 cm
90 g
1-year warranty
External
United Kingdom
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
2 km
Status Indicators
Port duplex mode, power, link/activity
Flow control, auto-negotiation, half duplex mode, full duplex mode
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
1 x Ethernet 10Base-T/100Base-TX - RJ-45 female , 1 x Ethernet 100Base-FX - ST multi-mode female x 2
FCC, RoHS
External power adapter
7.3 cm
9.7 cm
2.3 cm
90 g
Limited warranty - 1 year
50 °C
0 - 90%
6BDD StarTech.com 10/100 Ethernet to Multi Mode Fiber Media Converter SC 2 km In Stock £60.49
6BDD StarTech.com 10/100 Multi Mode Fiber Copper Fast Ethernet Media Converter ST 2 km In Stock £64.74
6BDD StarTech.com DC Power Adapter - 12V, 2A In Stock £11.72
6BDD StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 6BDD 051142
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £31.90
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Media Converter
Stock Status: While stocks last
Stock Status: Used Stock
Stock Status: Clearance
