Add an RS-232 serial port to your PC through a PCI expansion slot. The PCI1S550 16550 serial PCI card can be installed in a PCI slot to add one RS232 serial port - a cost-effective solution for connecting any new serial device or old legacy serial device, with data transfer rates of up to 115.2 Kbps.
Perfect for connecting serial modems, POS devices, PDAs, digital cameras, printers, ISDN terminal adapters and more, to your system, the 1 serial port PCI card supports IRQ sharing and operates flawlessly with Windows 7, Server 2008 R2, Vista, XP, Server 2003, 2000, ME, 98, 95, NT4, 3.1, DOS and Linux.
A convenient easy to install solution, the PCI serial card can be connected in minutes through simple plug and play installation.
- StarTech.com 1 Port PCI RS232 Serial Adapter Card with 16550 UART - PCI Serial Adapter - PCI rs232 - PCI Serial Card (PCI1S550) - serial adapter - PCI - RS-232
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- Ports
- RS-232
- Cabling Type
- V.24
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 920 Kbps
- System Requirements
- Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI
- Ports
- RS-232
- Connectivity Technology
- Wired
- Cabling Type
- V.24
- RS-232
- 920 Kbps
- 1 x RS-232 - 9 pin D-Sub (DB-9) - male - 1
- Compatible Slots
- 1 x PCI
- Plug and Play
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - parts and labour - lifetime
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £155.21 |
