8-Port PCI-Express DB9 RS-232 16C1050 UART 15kV ESD Protection. Add eight RS-232 DB9 serial ports to your desktop computer, through a PCIe expansion card slots. This PCI express serial card, with 8-port breakout cable, provides you with multiple ports to connect a wide variety of serial peripherals, at speeds of up to 921.4Kbps.
Connect your Peripherals with 8 Serial Ports
The PCI express serial port card makes it easy to add serial ports to connect your peripherals including printers, scanners, credit/debit card readers, PIN pads and modems, industrial controls and more. The 8 port PCIe serial card includes a breakout cable - with 8 DB9 connectors.
Maximum Compatibility
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments.
PEX8S1050 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
Connect your peripherals with 8 serial ports
The PCI express serial port card makes it easy to add serial ports to connect your peripherals including printers, scanners, credit/debit card readers, PIN pads and modems, industrial controls and more. The 8 port PCIe serial card includes a breakout cable - with 8 DB9 connectors. -
Maximum compatibility
- StarTech.com 8-Port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Card, 16C1050 UART, Multiport Serial DB9 Controller/Expansion Card, 15kV ESD Protection, Windows & Linux - Up to 921.6 Kbps Baud - serial adapter - PCIe - RS-232 x 8 - TAA Compliant
- Serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express
- PCI Specification Revision
- PCIe 1.1
- Ports
- RS-232 x 8
- 1.6 cm x 10.5 cm x 12 cm
- 74 g
- Cabling Type
- Serial RS-232
- Processor
- ASMedia ASM1083
- Yellow
- System Requirements
- Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / 7 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- TAA Compliant
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in card
- PCI Express
- PCIe 1.1
- Ports
- RS-232 x 8
- Connectivity Technology
- Wired
- Cabling Type
- Serial RS-232
- Flow control, 16550 UART support, 256-byte FIFO, 1.5KV ESD Protector
Processor / Memory
- Processor
- ASMedia ASM1083
- 8 x RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- 8 x hex nuts
- Cables Included
- 1 x DB-62 to DB-9 breakout cable - 48 cm
- MTBF
- 160,013 hours
- RoHS, WEEE
- Yellow
- TAA Compliant
- OS Required
- 1.6 cm
- 10.5 cm
- 12 cm
- 74 g
- Shipping Width
- 19 cm
- Shipping Depth
- 2.9 cm
- Shipping Height
- 6.5 cm
- Shipping Weight
- 700 g
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com Serial Null Modem Adapter | In Stock | £5.51 |
StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F | In Stock | £5.24 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.57 |
