StarTech.com 1 Port PCI Parallel Adapter Card
Quicklinx: 7RPXWS00 Mfr#: PCI1P2
The PCI1P2 1-Port Parallel PCI Card adds one ECP/EPP/SPP/BPP IEEE 1284 port to your PC, with support for data transfer speeds of up to 1.8Mbps.
This versatile card offers compatibility with PCI or PCI-X expansion slots (3.3/5V, 32/64-bit), as well as a simple plug and play installation with support and drivers for a broad range of operating systems including Windows 7, Server 2008 R2, XP Embedded DOS, Linux and more. The PCI Parallel card also features IRQ sharing and hot swapping capabilities, which guarantee convenient, hassle-free connections to any parallel peripheral.
This product is a replacement for the PCI1P card.
StarTech.com 1 Port PCI Parallel Adapter Card - parallel adapter - PCI-X - IEEE 1284
Parallel adapter
Plug-in card
Interface (Bus) Type
PCI-X
Ports
IEEE 1284
6.1 cm x 12.1 cm x 1.3 cm
70 g
Parallel
Data Transfer Rate
1.8 Mbps
Microsoft DOS, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Linux 2.4.x, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows Embedded Standard 2009, Linux 2.6.x, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / 7
Parallel adapter
Plug-in card
PCI-X
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
1.8 Mbps
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
Compatible Slots
1 x PCI-X
EN 61000-3-2, EN 61000-3-3, EN55024, WHQL, EN55022 Class B, FCC Part 15 B, RoHS
6.1 cm
12.1 cm
1.3 cm
70 g
Limited warranty - lifetime
60 °C
5 - 95%
