Add a USB-based RS232 Serial port to your laptop through an ExpressCard slot. The EC1S232U2 ExpressCard RS232 Serial Adapter Card (USB-based) (16950 UART) adds an RS232 (DB9) serial port to your ExpressCard-equipped laptop, enabling you to connect an RS232 serial peripheral device such as a plotter, digital signage device, receipt printer or bar code scanner through an available ExpressCard slot.
This USB-based ExpressCard supports RS232 serial data transfer rates up to 460 Kbps and eliminates the need to upgrade serial peripherals to more modern interfaces (e.g. USB, etc.) for the sake of host compatibility, saving both expense and hassle.
- StarTech.com 1 Port ExpressCard to RS232 DB9 Serial Adapter Card w/ 16950 - USB Based (EC1S232U2) - serial adapter - ExpressCard - RS-232
- Serial adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- ExpressCard/34
- Ports
- RS-232
- 3.5 cm x 11.5 cm x 1.8 cm
- 34 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 460.8 Kbps
- Processor
- Prolific PL-2303
- System Requirements
- Apple MacOS 9.x, Apple MacOS 8.x, Apple MacOS X 10.x, Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Server 2008
- Limited lifetime warranty
- Serial adapter
- Form Factor
- Plug-in module
- ExpressCard/34
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 460.8 Kbps
Processor / Memory
- Processor
- Prolific PL-2303
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x ExpressCard/34
- FCC, RoHS
- OS Required
- 3.5 cm
- 11.5 cm
- 1.8 cm
- 34 g
- Limited warranty - lifetime
- 0 °C
- 57 °C
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M | In Stock | £3.84 |
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F | In Stock | £4.29 |
StarTech.com 6ft Straight Through Serial Cable - DB9 M/F | In Stock | £3.53 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £4.19 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F | In Stock | £4.07 |
