StarTech.com 4 Port RS232 PCI Express Serial Card w/ Breakout Cable
Quicklinx: 7JFJWS00 Mfr#: PEX4S553B
Type: Serial adapter
Compatibility: Mac, PC
Interface: PCI Express
£77.60 ex VAT
£93.12 inc VAT
The PEX4S553B 4-Port PCI Express Serial Card (with breakout cable) lets you add 4 RS232 serial ports using a single PCIe expansion slot. The PCIe Serial Card includes a 1-to-4 break out cable, which enables you to add 4 serial ports to a single low profile slot.
The serial adapter card features a native single-chip design that provides optimum reliability and speed, reducing the CPU load by up to 48% over conventional bridge-chip serial cards - a cost-effective solution for connecting legacy serial devices to PCIe-enabled computers.
The multi-port serial adapter includes both full profile/height and low profile/half-height brackets for compatibility with standard and small form factor computers, and is compatible with a broad range of operating systems, including Windows 7/Server 2008 R2, 2003/Vista/XP (32 and 64 bit), Linux Kernel 2.6.11 and up, as well as MAC OS 10.5 and above.
This product is a replacement for the PEX4S552B card.
StarTech.com 4 Port PCI Express RS232 Serial Adapter Card - Single-Lane PCI Express - Breakout Cable - RS232 Extension - PCIe Serial Card (PEX4S553B) - serial adapter - PCIe - RS-232 x 4
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports
RS-232 x 4
2 cm x 7 cm x 6.2 cm
226 g
RS-232
Data Transfer Rate
250 Kbps
MCS9901
Microsoft DOS, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.4 - 10.10, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only
Serial adapter
Plug-in card
PCI Express
Ports
RS-232 x 4
Wired
RS-232
Data Transfer Rate
250 Kbps
Processor / Memory
MCS9901
4 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
RoHS
2 cm
7 cm
6.2 cm
226 g
Limited warranty - lifetime
70 °C
5 - 85%
7JFJ StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
7JFJ StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £37.72
7JFJ StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £158.99
7JFJ StarTech.com 1-Prt PCI Express Serial Card In Stock £38.69
7JFJ StarTech.com PCIe Dual Serial Port Card In Stock £40.31
7JFJ StarTech.com PCIe Dual Serial Port Card In Stock £44.79
Compatibility: Mac
Compatibility: PC
