This innovative USB to Serial adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to a laptop or desktop computer through USB - eliminating the expense of upgrading serial peripherals for compatibility.
A time-saving and convenient USB/Serial solution, the adapter retains assigned serial COM port values in nonvolatile memory, allowing the same values to automatically be assigned to the adapter serial port if disconnected and reconnected, or disconnected from one USB port and installed in another.
A versatile connectivity solution that bridges legacy serial peripheral devices with newer USB-capable computers, the USB to Serial adapter is compatible with Win98/2000/XP/Vista and MAC OS 10.4+ operating systems.
Versatile compatibility
This adapter cable works seamlessly with Mac systems, making it a practical choice for users looking to connect serial devices. -
Reliable serial connection
The 9-pin D-Sub (DB-9) male connector allows for dependable connection to a variety of RS-232 serial devices. -
Efficient data transfer
With a data transfer rate of 1 Mbps, this adapter provides quick communication between devices, ensuring effective operations. -
Compliant and safe
This product meets FCC standards, ensuring quality performance and safety for users. -
Compact and portable
Measuring 1 ft in length, this adapter is easy to carry and fits well in any workspace without clutter.
- StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention - serial adapter - USB - RS-232
- Serial adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- RS-232
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 1 Mbps
- Black
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Mobile 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Microsoft Windows CE 5.2, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Serial adapter
- Form Factor
- External
- USB
- Ports
- RS-232
- Connectivity Technology
- Wired
- RS-232
- 1 Mbps
- 1 x RS-232 - 9 pin D-Sub (DB-9) - male
- FCC
- Black
- OS Required
- Limited warranty - parts and labour - 2 years
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.73 |
StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention | In Stock | £31.73 |
StarTech.com Mountable 4 Port Rugged Industrial USB Hub | In Stock | £61.41 |
StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention | In Stock | £62.27 |
StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M | In Stock | £13.22 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter | In Stock | £7.93 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £24.85 |
StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention | In Stock | £45.96 |
StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter | In Stock | £46.21 |
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M | In Stock | £20.11 |
StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation | In Stock | £94.31 |
StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips | In Stock | £53.21 |
StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI | In Stock | £26.44 |
StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £88.60 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.43 |
StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable | In Stock | £147.94 |
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.42 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.02 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.35 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.16 |
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £4.57 |
StarTech.com USB to RS232 Serial Adapter | In Stock | £16.28 |
StarTech.com 4 Port USB to Serial Hub | In Stock | £78.51 |
StarTech.com USB C to RS232 Cable | In Stock | £21.66 |
StarTech.com USB C to DB25 Printer Cable | In Stock | £33.51 |
StarTech.com 4-Port USB to Serial Adapter | In Stock | £212.24 |
StarTech.com 8-Port USB to Serial Adapter | In Stock | £340.65 |
