StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M
Quicklinx: 7NZ6WS00 Mfr#: ICUSB232SM3
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB 2.0
35 In Stock
£20.11 ex VAT
£24.13 inc VAT
The ICUSB232SM3 3ft USB to Serial Adapter Cable lets you connect DB9 RS232 serial devices to your Mac or PC laptop or desktop computer through an available USB port, as though the computer offered an onboard DB9M connector.
Unlike typical USB to serial converter cables where the conversion takes place at the DB9 end of the cable, the StarTech.com ICUSB232SM3 features a converter chip on the USB end. Converting at the USB source overcomes the 15ft. technical limit of USB cables, allowing for a much greater serial DB-9 extension cable (50ft.+ is possible depending on the application), should it be necessary for a given setup.
Simple to install and use, this USB to Serial adapter provides a cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals.
  • Reliable connectivity
    The 3 ft length of this USB to RS232 DB9 serial adapter cable provides ample reach for connecting devices without excessive cable clutter.
  • Versatile compatibility
    Designed for use with Mac systems, this adapter ensures that users can easily integrate their RS-232 devices with modern computing environments.
  • Efficient power usage
    Those looking for a simple solution will appreciate that the adapter is USB-powered, eliminating the need for additional power sources.
StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M - serial adapter - USB 2.0 - RS-232
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232
Length
91.44 cm
42 g
RS-232
Data Transfer Rate
1 Mbps
Prolific PL-2303HX
Microsoft Windows Server 2003, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Microsoft Windows CE 5.2, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Serial adapter
External
USB 2.0
Ports
RS-232
Wired
RS-232
Data Transfer Rate
1 Mbps
USB powered
Processor / Memory
Prolific PL-2303HX
1 x RS-232 - 9 pin D-Sub (DB-9) - male
RoHS
Length
91.44 cm
42 g
Limited warranty - lifetime
-20 °C
80 °C
7NZ6 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.73
7NZ6 StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.73
7NZ6 StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.85
7NZ6 StarTech.com 3ft USB to RS232 DB9 Serial Adapter Cable - M/M In Stock £20.11
7NZ6 StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £25.85
7NZ6 StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £88.60
7NZ6 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
7NZ6 StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £147.94
7NZ6 StarTech.com USB to RS232 Serial Adapter In Stock £16.28
7NZ6 StarTech.com 4 Port USB to Serial Hub In Stock £78.51
7NZ6 StarTech.com UCB C to Serial Adapter In Stock £16.71
7NZ6 StarTech.com 4-Port USB to Serial Adapter In Stock £212.24
7NZ6 StarTech.com 8-Port USB to Serial Adapter In Stock £340.65
Compatibility: Mac
Compatibility: PC
Interface: USB 2.0
