StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention
Quicklinx: 4JDTWS00 Mfr#: ICUSB232PRO
Type: Serial adapter
Compatibility: Mac, PC
Interface: USB
25 In Stock
£21.73 ex VAT
£26.07 inc VAT
This innovative USB to Serial adapter offers a professional grade solution for connecting legacy or industrial RS232 serial devices to a laptop or desktop computer through USB - eliminating the expense of upgrading serial peripherals for compatibility.
A time-saving and convenient USB/Serial solution, the adapter retains assigned serial COM port values in nonvolatile memory, allowing the same values to automatically be assigned to the adapter serial port if disconnected and reconnected, or disconnected from one USB port and installed in another.
A versatile connectivity solution that bridges legacy serial peripheral devices with newer USB-capable computers, the USB to Serial adapter is compatible with Win98/2000/XP/Vista and MAC OS 10.4+ operating systems.
  • Versatile compatibility
    This adapter cable works seamlessly with Mac systems, making it a practical choice for users looking to connect serial devices.
  • Reliable serial connection
    The 9-pin D-Sub (DB-9) male connector allows for dependable connection to a variety of RS-232 serial devices.
  • Efficient data transfer
    With a data transfer rate of 1 Mbps, this adapter provides quick communication between devices, ensuring effective operations.
  • Compliant and safe
    This product meets FCC standards, ensuring quality performance and safety for users.
  • Compact and portable
    Measuring 1 ft in length, this adapter is easy to carry and fits well in any workspace without clutter.
StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention - serial adapter - USB - RS-232
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
RS-232
Data Transfer Rate
1 Mbps
Microsoft Windows 98 Second Edition, Microsoft Windows Server 2003, Microsoft Windows Embedded Standard 2009, Microsoft Windows Mobile 5.0, Microsoft Pocket PC 2003, Microsoft Windows CE 4.2, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Mobile 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Microsoft Windows CE 5.2, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
1 Mbps
1 x RS-232 - 9 pin D-Sub (DB-9) - male
FCC
Limited warranty - parts and labour - 2 years
4JDT StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £21.73
4JDT StarTech.com 1 Port Professional USB to Serial Adapter Cable with COM Retention In Stock £31.73
4JDT StarTech.com Mountable 4 Port Rugged Industrial USB Hub In Stock £61.41
4JDT StarTech.com 6 ft Professional RS422/485 USB Serial Cable Adapter with COM Retention In Stock £62.27
4JDT StarTech.com USB to RS232 DB9/DB25 Serial Adapter Cable - M/M In Stock £13.22
4JDT StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
4JDT StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
4JDT StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
4JDT StarTech.com 2 Port USB to RS232 RS422 RS485 Serial Adapter with COM Retention In Stock £80.49
4JDT StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter In Stock £7.93
4JDT StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £24.85
4JDT StarTech.com 2 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £45.96
4JDT StarTech.com 24in Internal USB Motherboard Header to 2 Port Serial RS232 Adapter In Stock £46.21
4JDT StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with Optical Isolation In Stock £94.31
4JDT StarTech.com 2 Port Industrial Wall Mountable USB to Serial Adapter Hub with DIN Rail Clips In Stock £54.05
4JDT StarTech.com 1 Port USB to Null Modem RS232 DB9 Serial DCE Adapter Cable with FTDI In Stock £26.44
4JDT StarTech.com 4 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £88.60
4JDT StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.43
4JDT StarTech.com 8 Port USB to DB9 RS232 Serial Adapter Hub – Industrial DIN Rail and Wall Mountable In Stock £151.52
4JDT StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.02
4JDT StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.35
4JDT StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £5.01
4JDT StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
4JDT StarTech.com USB to RS232 Serial Adapter In Stock £16.28
4JDT StarTech.com 4 Port USB to Serial Hub In Stock £78.51
4JDT StarTech.com USB C to RS232 Cable In Stock £21.66
4JDT StarTech.com USB C to DB25 Printer Cable In Stock £33.51
4JDT StarTech.com 4-Port USB to Serial Adapter In Stock £212.24
4JDT StarTech.com 8-Port USB to Serial Adapter In Stock £340.65
Compatibility: Mac
Compatibility: PC
Interface: USB
