StarTech.com 1.8m 6 ft USB C to mDP Cable
Quicklinx: DHNWWS00 Mfr#: CDP2MDPMM6B
19 In Stock
£16.59 ex VAT
£19.90 inc VAT
Use this cable to connect your USB Type-C computer directly to a Mini DisplayPort monitor, without additional adapters. This USB-C to Mini DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your Mini DP monitor. The adapter offers a connection distance of up to 1.8 m (6 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1.8 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For shorter installations, StarTech.com also offers a 1 m (3 ft.) USB-C to Mini DisplayPort cable (CDP2MDPMM1MB), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
StarTech.com 6ft / 2m USB-C to Mini DisplayPort Cable - 4K 60Hz - Black - USB 3.1 Type C to mDP Adapter (CDP2MDPMM6B) - DisplayPort cable - 24 pin USB-C to Mini DisplayPort - 1.8 m
DisplayPort cable
4K60Hz (3840 x 2160) support, DisplayPort Alternate Mode support, 5.1 audio channel support
Length
1.8 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
Mini DisplayPort - male (output)
USB 3.1 / Thunderbolt 3 / DisplayPort 1.2
3-year warranty
DisplayPort cable
Length
1.8 m
58 g
Connector
USB 3.1 / Thunderbolt 3 / DisplayPort 1.2, FCC, RoHS
Shipping Width
1.2 cm
Shipping Depth
22 cm
Shipping Height
0.8 cm
3-year warranty
DHNW StarTech.com 6ft USB-C to DisplayPort Cable In Stock £23.07
DHNW StarTech.com 2m USB-C to HDMI Cable In Stock £28.73
DHNW StarTech.com 1m USB-C to HDMI Cable In Stock £25.98
DHNW StarTech.com 1m USB-C to VGA Cable In Stock £19.52
DHNW StarTech.com 2m USB-C to VGA Cable In Stock £21.01
DHNW StarTech.com 3m USB C to DisplayPort Cable - White In Stock £12.80
DHNW StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £16.59
DHNW StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.05
