StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m
Quicklinx: DXDMWS00 Mfr#: CDP2MDPMM1MB
Type: DisplayPort
Length: 1m
49 In Stock
£19.75 ex VAT
£23.70 inc VAT
Use this cable to connect your USB Type-C computer directly to a Mini DisplayPort monitor, without additional adapters. This USB-C to Mini DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your Mini DP monitor. The adapter offers a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For longer installations, StarTech.com also offers a 1.8 m (6 ft.) USB-C to Mini DisplayPort cable (CDP2MDPMM6B), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
  • High-resolution support
    This cable supports a maximum output resolution of 3840 x 2160, allowing for crisp and clear visuals suitable for high-definition displays.
  • Broad compatibility
    Designed to be compatible with USB 3.1 and Thunderbolt 3 standards, this cable provides flexibility in connecting various devices.
  • Audio enhancement
    The cable supports 5.1 audio channels, ensuring sound to accompany your visual content for an engaging viewing experience.
  • Alternate mode functionality
    With DisplayPort Alternate Mode support, this cable allows USB-C devices to connect to Mini DisplayPort displays, expanding your connectivity options.
  • Robust design
    The construction of this cable ensures reliability and performance, making it suitable for everyday use in various environments.
StarTech.com 1m / 3.3ft USB-C to Mini DisplayPort Cable - 4K 60Hz - Black - USB 3.1 Type C to mDP Adapter (CDP2MDPMM1MB) - video adapter cable - 24 pin USB-C to Mini DisplayPort - 1 m
Video adapter cable
4K60Hz (3840 x 2160) support, DisplayPort Alternate Mode support, 5.1 audio channel support
Length
1 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
Mini DisplayPort - male (output)
USB 3.1 / Thunderbolt 3 / DisplayPort 1.2
3-year warranty
Video adapter cable
Length
1 m
25 g
Connector
USB 3.1 / Thunderbolt 3 / DisplayPort 1.2, FCC, RoHS
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.2 cm
Shipping Weight
30.5 g
3-year warranty
DXDM StarTech.com 2m USB-C to HDMI Cable In Stock £27.69
DXDM StarTech.com 1m USB-C to HDMI Cable In Stock £25.04
DXDM StarTech.com 1m USB-C to VGA Cable In Stock £19.38
DXDM StarTech.com 2m USB-C to VGA Cable In Stock £20.80
DXDM StarTech.com 3m USB C to DisplayPort Cable - White In Stock £19.74
Type: DisplayPort
Length: 1m
