Use this cable to connect your USB Type-C computer directly to a Mini DisplayPort monitor, without additional adapters. This USB-C to Mini DisplayPort adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your Mini DP monitor. The adapter offers a connection distance of up to 1.8 m (6 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1.8 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For shorter installations, StarTech.com also offers a 1 m (3 ft.) USB-C to Mini DisplayPort cable (CDP2MDPMM1MB), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
High-resolution output
Delivers a maximum output resolution of 3840 x 2160 at 60 Hz, suitable for high-definition displays. -
Versatile connectivity
Equipped with a USB-C connector and Mini DisplayPort, this cable connects a wide range of devices. -
Audio support
Supports 5.1 audio channels for an engaging sound experience alongside high-quality video. -
Advanced compatibility
Compliant with USB 3.1, Thunderbolt 3, and DisplayPort 1.2 standards for usability with various technologies. -
Reliable construction
Built to last with a 6 ft length, providing ample reach for versatile setups without sacrificing performance.
- StarTech.com 6ft / 2m USB-C to Mini DisplayPort Cable - 4K 60Hz - Black - USB 3.1 Type C to mDP Adapter (CDP2MDPMM6B) - video adapter cable - 24 pin USB-C to Mini DisplayPort - 1.8 m
- Video adapter cable
- 4K60Hz (3840 x 2160) support, DisplayPort Alternate Mode support, 5.1 audio channel support
- Length
- 1.8 m
- Connector
- 24 pin USB-C - male (input)
- Connector (Second End)
- Mini DisplayPort - male (output)
- USB 3.1 / Thunderbolt 3 / DisplayPort 1.2
- Black
- 3-year warranty
- Length
- 1.8 m
- Black
- 58 g
- Connector
- USB 3.1 / Thunderbolt 3 / DisplayPort 1.2, FCC, RoHS
- Shipping Width
- 1.2 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 0.8 cm
- 3-year warranty
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £18.75 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.94 |
StarTech.com 1m USB-C to HDMI Cable | In Stock | £25.27 |
StarTech.com 1m USB-C to VGA Cable | In Stock | £19.38 |
StarTech.com 2m USB-C to VGA Cable | In Stock | £22.00 |
StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £20.18 |
StarTech.com 1.8m 6 ft USB C to mDP Cable | In Stock | £10.47 |
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m | In Stock | £20.26 |
