StarTech.com 1m USB-C to HDMI Cable
Quicklinx: CHN3WS00 Mfr#: CDP2HDMM1MB
17 In Stock
£25.04 ex VAT
£30.04 inc VAT
Eliminate clutter by connecting your USB Type-C computer directly to an HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television or projector. The adapter supports a connection distance of up to 1 m (3 ft.) and works with USB-C devices that support DP alt mode, such as the MacBook, ChromeBook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For longer installations, a 2 m (6 ft.) USB-C to HDMI cable enabl you to choose the right cable length for your custom installation needs.
The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display.
The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
Your USB-C equipped device must support video (DP alt mode) to work with this adapter.
  • Clutter-free installation
  • Hassle-free connection with USB Type-C
  • Astonishing picture quality
    At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
StarTech.com USB C to HDMI Cable - 3 ft / 1m - USB-C to HDMI 4K 30Hz - USB Type C to HDMI - Computer Monitor Cable (CDP2HDMM1MB) - external video adapter
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
Interfaces Details
HDMI (male connector)
Length
1 m
3-year warranty
P/N: TB33A1C
Bus Type
USB-C
Max Resolution
3840 x 2160
Interfaces Details
FCC, RoHS, WEEE
Length
1 m
Limited warranty - 3 years
45 °C
5 - 95% (non-condensing)
P/N: TB33A1C
CHN3 StarTech.com USB-C to VGA Adapter In Stock £21.62
CHN3 StarTech.com USB-C to HDMI Adapter In Stock £18.89
CHN3 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £7.79
CHN3 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £17.91
CHN3 StarTech.com 2m USB-C to DVI Cable In Stock £22.21
CHN3 StarTech.com 2m USB-C to HDMI Cable In Stock £27.69
CHN3 StarTech.com 1m USB-C to DVI Cable In Stock £10.98
CHN3 StarTech.com 1m USB-C to HDMI Cable In Stock £25.04
CHN3 StarTech.com 1m USB-C to VGA Cable In Stock £19.38
CHN3 StarTech.com 2m USB-C to VGA Cable In Stock £20.80
CHN3 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.36
CHN3 StarTech.com 6 ft USB C to DP Cable - White In Stock £9.58
CHN3 StarTech.com 3m USB C to DisplayPort Cable - White In Stock £19.74
CHN3 StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £19.74
CHN3 StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £10.35
CHN3 StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £19.75
CHN3 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.05
CHN3 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £22.84
CHN3 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.81
CHN3 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
CHN3 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.56
CHN3 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £16.99
CHN3 StarTech.com 6.6ft USB C to DP 1.2 Cable In Stock £22.26
