Connect your USB Type-C devices to your computer, with reduced clutter. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall charger, car charger or power bank.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices from your laptop.
You can also use the cable to charge your USB-C devices from a USB-A wall charger, car charger or power bank. It's the ideal cable for commuters, for in-car use or to reduce clutter when syncing with your laptop.
Replace the USB-C charging cable that came with your device or keep one as a spare in your laptop bag, backpack or other carrying case.
Durable shielding
The cable is built with double shielding using aluminum mylar foil and braid, which significantly reduces the risk of signal loss and provides robust protection against environmental wear. -
Versatile connectivity
Featuring a male USB Type-A connector on one end and a male USB-C connector on the other, this cable allows for seamless connections between legacy devices and the latest technology. -
Environmentally compliant
The cable meets RoHS and WEEE standards, ensuring adherence to environmentally sustainable practices during manufacturing and disposal. -
Efficient power delivery
Designed for syncing and charging, this cable supports efficient power delivery to connected devices, ensuring fast and reliable operation. -
Flexible design
The PVC jacket provides flexibility and resistance to everyday wear, making the cable easy to manage while ensuring long-lasting performance.
- StarTech.com 0.5m USB C to USB A Cable - M/M - USB 2.0 - USB-C Charger Cable - USB 2.0 Type C to Type A Cable - USB A to C (USB2AC50CM) - USB cable - USB to 24 pin USB-C - 50 cm
- USB cable
- Technology
- Double shielded
- Sync and charge
- Length
- 50 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: DKT30CVAGPD
- USB cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Sync and charge
- Length
- 50 cm
- Black
- 23 g
- Connector
- USB / USB 2.0, RoHS, WEEE
- Designed For
- P/N: DKT30CVAGPD
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £10.31 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.87 |
StarTech.com 4m USB 2.0 C to A Cable M/M | In Stock | £16.01 |
StarTech.com 0.5m USB 2.0 C to A Cable M/M | In Stock | £7.94 |
StarTech.com 1m USB A to C Cable - USB 2.0 | In Stock | £9.77 |
