StarTech.com 4m USB 2.0 C to A Cable M/M
Quicklinx: CTWBWS00 Mfr#: USB2AC4M
Length: 4m
£15.39 ex VAT
£18.46 inc VAT
Connect your USB Type-C devices to your computer, over longer distances. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall or car charger.
The non-standard 4-meter cable gives you the extra length you need to overcome distance restrictions and stay connected. You can charge and sync your USB-C mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
The cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 2.0 specifications. This includes all environmental, electrical and mechanical standards, ensuring a reliable, high-quality cable for all of your USB-C devices.
  • Versatile Connectivity
    The cable features a 24-pin USB-C connector on one end and a 4-pin USB Type-A connector on the other, allowing for easy connections across a wide range of devices.
  • Reliable Performance
    Compliant with USB-IF standards, this cable ensures dependable performance for both charging and syncing tasks.
StarTech.com 4m 13ft USB C to A Cable - USB 2.0 USB-IF Certified - USB Type C to USB Type A Cable M/M - USB-C Charging Cable - USB A to C (USB2AC4M) - USB-C cable - 24 pin USB-C to USB - 4 m
USB-C cable
Sync and charge
Length
4 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
USB-C cable
Sync and charge
Length
4 m
Connector
24 pin USB-C - male
USB / USB 2.0, USB-IF
CTWB StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £8.64
CTWB StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.44
CTWB StarTech.com 4m USB 2.0 C to A Cable M/M In Stock £15.39
CTWB StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £7.99
CTWB StarTech.com 1m USB A to C Cable - USB 2.0 In Stock £9.53
Length: 4m
