StarTech.com 0.5m USB 2.0 C to A Cable M/M
Quicklinx: CTWCWS00 Mfr#: USB2AC50CM
Length: 50cm
32 In Stock
£7.94 ex VAT
£9.52 inc VAT
Connect your USB Type-C devices to your computer, with reduced clutter. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall charger, car charger or power bank.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices from your laptop.
You can also use the cable to charge your USB-C devices from a USB-A wall charger, car charger or power bank. It's the ideal cable for commuters, for in-car use or to reduce clutter when syncing with your laptop.
Replace the USB-C charging cable that came with your device or keep one as a spare in your laptop bag, backpack or other carrying case.
  • Durable shielding
    The cable is built with double shielding using aluminum mylar foil and braid, which significantly reduces the risk of signal loss and provides robust protection against environmental wear.
  • Versatile connectivity
    Featuring a male USB Type-A connector on one end and a male USB-C connector on the other, this cable allows for seamless connections between legacy devices and the latest technology.
  • Environmentally compliant
    The cable meets RoHS and WEEE standards, ensuring adherence to environmentally sustainable practices during manufacturing and disposal.
  • Efficient power delivery
    Designed for syncing and charging, this cable supports efficient power delivery to connected devices, ensuring fast and reliable operation.
  • Flexible design
    The PVC jacket provides flexibility and resistance to everyday wear, making the cable easy to manage while ensuring long-lasting performance.
StarTech.com 0.5m USB C to USB A Cable - M/M - USB 2.0 - USB-C Charger Cable - USB 2.0 Type C to Type A Cable - USB A to C (USB2AC50CM) - USB cable - USB to 24 pin USB-C - 50 cm
USB cable
Double shielded
Sync and charge
Length
50 cm
Connector
4 pin USB Type A - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
P/N: DKT30CVAGPD
USB cable
Double shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Sync and charge
Length
50 cm
23 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE
P/N: DKT30CVAGPD
CTWC StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £10.31
CTWC StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
CTWC StarTech.com 4m USB 2.0 C to A Cable M/M In Stock £16.01
CTWC StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £7.94
CTWC StarTech.com 1m USB A to C Cable - USB 2.0 In Stock £9.77
Length: 50cm
