Connect your USB Type-C devices to your computer, with reduced clutter. This USB-C to USB-A cable makes it easy to charge and sync USB Type-C mobile devices using the USB-A port on your computer or a standard USB-A wall charger, car charger or power bank.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices from your laptop.
You can also use the cable to charge your USB-C devices from a USB-A wall charger, car charger or power bank. It's the ideal cable for commuters, for in-car use or to reduce clutter when syncing with your laptop.
Replace the USB-C charging cable that came with your device or keep one as a spare in your laptop bag, backpack or other carrying case.
- StarTech.com 0.5m USB C to USB A Cable - M/M - USB 2.0 - USB-C Charger Cable - USB 2.0 Type C to Type A Cable - USB A to C (USB2AC50CM) - USB cable - USB to 24 pin USB-C - 50 cm
- USB cable
- Technology
- Double shielded
- Sync and charge
- Length
- 50 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: DKT30CVAGPD
- USB cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Sync and charge
- Length
- 50 cm
- Black
- 23 g
- Connector
- USB / USB 2.0, RoHS, WEEE
- Designed For
- P/N: DKT30CVAGPD
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.21 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.26 |
StarTech.com 4m USB 2.0 C to A Cable M/M | In Stock | £19.23 |
StarTech.com 0.5m USB 2.0 C to A Cable M/M | In Stock | £7.94 |
StarTech.com 1m USB A to C Cable - USB 2.0 | In Stock | £11.30 |
