StarTech.com 0.5m Blue Cat5e Patch Cable
Quicklinx: CRFKWS00 Mfr#: 45PAT50CMBL
Length: 50cm
Colour: Blue
More than 50 In Stock
£3.74 ex VAT
£4.48 inc VAT
The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
  • Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
  • Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
  • Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
StarTech.com 0.5m Blue Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Snagless, stranded, PoE ready
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Copper
Length
50 cm
26 g
Blue
Connector
RJ-45 - male
RJ-45 - male
Up to 350 MHz
CRFK StarTech.com 0.5m Blue Cat5e Patch Cable In Stock £3.74
CRFK StarTech.com 0.5m Green Cat5e Patch Cable In Stock £2.44
CRFK StarTech.com 0.5m Red Cat5e Patch Cable In Stock £2.44
CRFK StarTech.com 0.5m White Cat5e Patch Cable In Stock £3.73
CRFK StarTech.com 0.5m Yellow Cat5e Patch Cable In Stock £3.77
CRFK StarTech.com 0.5m Orange Cat5e Patch Cable In Stock £2.44
CRFK StarTech.com 0.5m Black Cat5e Patch Cable In Stock £3.96
Length: 50cm
Colour: Blue
