The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
- Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
- Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
- Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
- StarTech.com 0.5m Red Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - red
- Patch cable - CAT 5e
- Technology
- Snagless, stranded, PoE ready
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Copper
- Length
- 50 cm
- 26 g
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 350 MHz
StarTech.com 0.5m Blue Cat5e Patch Cable | In Stock | £3.98 |
StarTech.com 0.5m Green Cat5e Patch Cable | In Stock | £2.44 |
StarTech.com 0.5m Red Cat5e Patch Cable | In Stock | £2.44 |
StarTech.com 0.5m White Cat5e Patch Cable | In Stock | £3.73 |
StarTech.com 0.5m Yellow Cat5e Patch Cable | In Stock | £3.77 |
StarTech.com 0.5m Orange Cat5e Patch Cable | In Stock | £2.44 |
StarTech.com 0.5m Black Cat5e Patch Cable | In Stock | £3.96 |
