This 46-inch LED display offers you astounding 1920 x 1080 Full HD high quality images to bring excellent color reproduction and high visibility for indoor applications. The FWD-46B2 features a slim installation design and incorporates innovative LED backlighting - offering low power consumption and thus saving on running costs.
The public display has been designed to be mounted horizontally and vertically for use in a variety of digital signage applications including retail.
Low power and environmentally-conscious
The FWD-46B2 offers low power consumption with LED backlighting. This feature helps to reduce the total cost of ownership by lowering the running cost. -
High quality images
The display achieves high brightness and a high contrast ratio of 4000:1. This quality helps to enable excellent color reproduction and high visibility in indoor applications. -
Slim installation design
The depth of the FWD-46B2 is at least 30% less than that of a conventional CCFL model from Sony. For slim installation, the signal in and signal out terminals are incorporated into this profile, and do not protrude from the unit. -
Landscape/portrait - adaptable for a variety of applications
Use of commercial-grade LCD panel and cooling systems, ensure the display can be positioned either vertically (portrait) or horizontally (landscape) with no change in the backlight level or service life. This flexibility in orientation makes it possible to create many different imaging effects in a wide variety of spaces. -
Display control via RS232C/RJ45
Users can monitor the display status and control multiple displays over a LAN, VPN, or the Internet. -
Multi-display
The display can present a single large dynamic image, simply by combining up to 16 display units (1 x 2, 1 x 3, 1 x 4, 2 x 1, 3 x 1, 4 x 1,2 x 2, 3 x 3, 4 x 4). -
Screen saver
Images with constant brightness (such as data and still images) can cause screen burn-in on a display. To prevent this, three screen saver patterns are provided which can be adapted. -
Eco mode
With the eco mode function, power consumption is reduced using power-saving technology. Compared with standard mode, power consumption using the high setting is less in eco mode and using the low setting is less in eco mode. -
VESA-compliant flexible mounting
VESA-compliant mounting points help ensure safety when units are mounted. -
Control panel lock
The control panel lock function can disable the control panel of a display to prevent unauthorized changes to display settings. -
Power-on delay
Switching on multiple displays at the same time can potentially cause a damaging power surge. The power-on delay feature avoids this risk by allowing the user to staggering the timing so that each unit powers up at a slightly different time.
- Sony FWD-46B2 - 46" LED-backlit LCD flat panel display
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Size
- 46"
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- Video Interface
- Component, composite, HDMI
- LCD Backlight Technology
- LED backlight
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Remote Control
- Remote control
- Product Type
- Diagonal Size
- 46"
- TV Tuner
- No tuner
- Video Interface
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p (FullHD)
- LED backlight
- Colour Depth
- Up to 1.06 billion colours
- Viewing Angle
- 178 degrees
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- External Speakers Amplifier Power (Total)
- 14 Watt
- Power Device
- Power supply
- 0 °C
