Skullcandy Indy Fuel True Wireless In-Ear Headphones - Grey
Quicklinx: G032WS00 Mfr#: S2IFW-N744
TRUE FREEDOM, EFFORTLESS CHARGING.
CHARGE THE CASE WITHOUT WIRES.
True wireless means no wires. And, with Indy Fuel, even the case can charge wirelessly. Just drop it on your favorite wireless charging pad (or pair it with one of our Fuelbase™ series of chargers). Together, the case and buds hold up to 30 hours of total play time.
USE EITHER BUD BY ITSELF.
Sometimes, you just want to use one earbud, while you keep your other ear free to hear what’s around you. No problem. With Indy Fuel, you can use either the left or right earbud solo.
CONTROL WITHOUT YOUR PHONE.
A simple series of touches control everything directly from your buds. Answer calls, skip tracks, adjust volume, activate an assistant, switch EQ modes, even turn on Ambient Mode to hear more of your surroundings—all without ever touching your device.
NEVER LOST WITH TILE.
Built-in Tile™ technology makes it easy to track down either earbud if you ever misplace them. Download the Tile app and follow the instructions to activate.
DURABLE AND REPLACEABLE.
Indy Fuel earbuds are resistant to water, sweat and dust. And just in case any part is lost or damaged, our Fearless Use Promise® means we’ll replace it at a discount.
  • Charge the case without wires
    True wireless means no wires. And, with Indy Fuel, even the case can charge wirelessly. Just drop it on your favorite wireless charging pad. Together, the case and buds hold up to 30 hours of total play time.
  • Use either bud by itself
    Sometimes, you just want to use one earbud, while you keep your other ear free to hear what's around you. No problem. With Indy Fuel, you can use either the left or right earbud solo.
  • Control without your phone
    A simple series of touches control everything directly from your buds. Answer calls, skip tracks, adjust volume, activate an assistant, switch EQ modes, even turn on Ambient Mode to hear more of your surroundings - all without ever touching your device.
  • Never lost with Tile
    Built-in Tile technology makes it easy to track down either earbud if you ever misplace them.
  • Durable and replaceable
Skullcandy Indy Fuel - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Portable electronics
Chill grey
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
True wireless earphones - Bluetooth - wireless
57 g
Chill grey
Recommended Use
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.0
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Total Harmonic Distortion (THD)
<3%
Impedance
32 Ohm
Diaphragm
6 mm
Microphone
Built-in
Charging case, 3 pairs of EarGels, USB-C charging cable
Headphone battery rechargeable
Run Time Details
Continuous playback (with included charging case): up to 30 hours
