The PN-V602 video wall monitor combines the slimmest bezel available on a 60" class LCD monitor with high brightness for semi-outdoor environments. With 24/7 reliability and an almost seamless bezel, the PN-V602 sets a standard for video wall displays. A full-array LED backlight helps ensure uniform brightness. Local dimming also helps deliver a remarkably better contrast ratio and brightness compared to conventional LCD monitors, while utilizing significantly less power.
60" class screen size
Sharp ASV LCD technology provides exceptionally deep blacks and bright vivid colors. -
Local dimming - for high contrast and superb energy efficiency
Local dimming allows specific groups of LEDs to be dimmed. This helps deliver remarkably higher contrast and significant power savings. -
Slimmest bezel on a 60" class LCD monitor
Thanks to its ultra-slim bezel, multiple PN-V602 monitor can be joined together to create high impact multi-screen displays. -
Full array LED backlight
It gives the PN-V602 more uniform brightness than conventional CCFL backlighting. LED elements are positioned across the entire panel directly behind the liquid crystal layers, helping ensure beautiful uniform images. -
Enlarge display mode
The frame width adjustment function eliminates misalignment and helps enhance the enlarged image in a multi-screen display. -
Extensive interface capability
Standard interfaces include HDMI input, D-Sub 15-pin RGB input, stereo audio input, stereo audio line-output and RS-232C input/output.
- Sharp PN-V602 PN-V Series - 60" LED-backlit LCD display - HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 60"
- Commercial Use
- Yes - digital signage
- Resolution
- 1366 x 768
- Display Format
- 720p
- Max Number of Screens
- 25
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- Technology
- UV²A
- LCD Backlight Technology
- LED backlight local dimming
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Hardware Diagnosis
- Voltage
- AC 120/230 V (50/60 Hz)
- 510 Watt
- Dimensions (WxDxH) - without stand
- 133.59 cm x 14.93 cm x 75.42 cm
- 45 kg
- 3-year warranty
- Product Type
- 510 Watt
- Diagonal Class
- 60"
- Commercial Use
- Series
- PN-V Series
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- Brightness sensor
- Video Interface
- HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- VGA (HD-15)
- Modes
- Portrait mode, landscape mode, Mirror Display Mode
- Dimensions
- Without stand
- 133.59 cm
- 14.93 cm
- 75.42 cm
- 45 kg
Display
- LCD Display Technology
- UV²A
- Resolution
- 1366 x 768
- Display Format
- 720p
- 16:9
- Image Contrast Ratio
- 5000:1
- Dynamic Contrast Ratio
- 1000000:1
- Brightness
- 1500 cd/m²
- Viewing Angle
- 176 degrees
- Viewing Angle (Vertical)
- 176 degrees
- Response Time
- 6 ms
- Backlight Life
- 50,000 hour(s)
- Certified for 24/7 Continuous Operation, Bezel Correction
Video Wall
- 25
Stands & Mounts
- Flat Panel Mount Interface
- 200 x 200 mm
- Connector Type
- HDMI input , VGA input , Audio line-in , Serial input , Serial output , Audio line-out
- Plug and Play, GOST, CB
- Power Device
- Power supply
- Input Voltage
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80%
